Where is the air induction valve located on a jetted tub? I have no manufacturer's info and no controls are visible as the tub surround is in a plastic enclosure.
Lumpy816
  • 246 Answers
SOURCE: Kenmore Elite Model 27086603 Trapped clothing
Where the front panel and the top of the machine meet, there is a crack. When using a flashlight, you will see 4 items in this crack. 2 are green 2 are black. The black peices are support studs, ignore them. The green one's are clips that hold the top to the front. Using a putty knife (easier) or a small flat head screw driver (a bit more difficult) push one of the green clips towards the rear of the machine while lifting on the top. Only lift slightly (too far and it will bind on those support studs I told you about) Now press the clip on the other side and lift the top up. Now you should see your tub (from a new perspective) you will see a plastic ring around the top of the tub. Disconnect the green clamp on the hose towards the left rear using a pair of pliers or channel locks. The ring is held down with clips all of the way around the tub. By pressing down over each clip and pulling the lips slightly forward, you can remove the top ring. The rest is the easiest part. In the center of the basket, there is a small cap. Rremove this with a small flat head screwdriver. Remove the bolt that is underneath the cap. Now lift the whole basket out. If your small items get too far (ie, the pump), remove the back panel. On the left hand side you will see a small black hose towards the botom. this connects to the pump. Forign objects can ldge in here keeping it from draining also. If you disconnect the hoses, have something handy for all of the water to go into (large wet vac is usually the best). Drop the 3 #20 torx screws and the pump will come down and you can remove the obstructions.
Posted on Jun 19, 2008
SOURCE: cannot find idle air control valve
3.0 and 3.8 engines are next to the throttle body [throttle cable hooks to it] and is bolted down with two 5/16 head bolts,is about three inchs long and 1 1/2 round
Posted on Jan 17, 2009
PartsCenter
  • 125 Answers
SOURCE: Kohler K1338 spa tub controls messing up
no it is not damaged. that is the way it is operated. it always resets to the bottom jets first.
Posted on Mar 04, 2009
  • 80 Answers
SOURCE: Leaks from jets along outer wall
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Posted on Aug 19, 2009
dmsr63
  • 2050 Answers
SOURCE: having trouble locating my idle air control valve
looking at the throttle body assembly, after removing the air filter housing, opposite side of the spark plugs, about an inch or two down, you should see a electrical connection, with four wires, the IAC has two small torxs screws that hold it to the throttle body.
Posted on Dec 22, 2009
Why are jets on spa not working?
ck your jet air intake controls , these are usually located around top edge of tub some where , they can be rotary valves or slide type ,depends on type of tub you have . I find most times when someone complains of this I find the jets are turned way down or off
Jan 27, 2016 | Pool & Spa
I have a jacuzzi whirlpool tub in my home that has started to leak at the three button control panel. Flooded out the bathroom so I cut a hole in the tile surround and when the pump is running it leak
First thing you need to do is remove some skirting so you can actually see where the water is coming from.
The 3 position control panel would only leak if the water was above it or covering it if it is located in the wall of the tub. That solution would only require the bather to NOT fill the tub quite so full.
IF however the water is coming from another location then that will be noticeable when you are checking for the water leak.
Dec 07, 2014 | Jacuzzi Home
When pump runs on our spa we are getting air bubbles through the jest even though the vales are closed. Dreamaker Spa older model
id say even though you think your air induction valves are closed they in fact are not , if all the jets get air in them look for leaks in pump or piping this might be more evedent if run slow or off as pump cant suck air in hole if its off , if not air induction valves can be rebuilt by obtaining the parts from mfg
Sep 26, 2014 | Pool & Spa
Maax sa9592 06
Each bathtub has at least one air control on the tub that when opened lets air into the jets that produce the bubbles.
If you are experiencing too much pressure out of each jet, some of the jets if they are adjustable you can turn them down by rotating them left or right.
The other issue may be the water depth in the tub before you are turning it on. Make sure the water level is at least two inches or more above the highest jet.
Rod
US Parts Center
Feb 05, 2014 | Home
I have just refilled by hot tub with a balboa 500z pump. After refilling it the pump is working fine but the jets are not. The dr light has come up. Please can someone help me bleed the pump to get it...
Priming can be done many different ways depending on thetubs design. Some tub manufactures provide bleed valves located on the plumbingjust beyond the pump and heater unions. Some pumps have a bleed valve locatedon the pump. If there are no bleed valves then you will have to release theunion nuts to allow the air to escape.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Hope that helps.
Jun 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
One of the "Air Volume Control" valves shoots
you can change out the complete air control valve. One thing i would have you do before changing that out is to make sure all of the jet faces are turned on. to do this turn the face of the jet clockwise. this will let the maximum amount of water come out of each jet face.
Sometimes if there are adjustable jets in the tub and they all get shut off, it will force the water that should be coming out of the jet faces back through the system and out the air control knob if it is open.
Just to check. that may not be the case....but...that would be cool if it were.
Jan 20, 2011 | American Standard Colony Hydro Massage...
Water coming out of adjustable air vent behind wall of tub
one or more of the jets are turned off. i would suspect someone is plugging the jets off which causes water to go backwards in the system and the water goes out the air controls. solution: check the jets to make sure the jet faces are turned on and/or tell someone to quit plugging off the jets when they are in the tub.
Mar 03, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Apr 24, 2009 | Home
How to identify make and model of old whirlpool tub?
This is a problem common to all whirlpool/air jet style tubs. The pumps become air locked due to the water evaporating from lack of use. All tubs need, and have, SOME means of priming the pump, this is most likely what the problem was, originally, for you. This time in particular you found it to be electrical in nature but for future reference, for you and all who have these style of tubs, I am putting this out there. Some where on the tub, usually along the top edge of the tub is a vent knob that controls the amount of air that the pump is allowed to mix with the water for the jets, usually by closing this valve all the way (tub needs to be full of water of course) and running the pump for a minute or 2, you should be able to get the pump pumping water again, if not you may need to do something else with your particular set-up to get it purged of air, the pumps in jacuzzi tubs are designed to pump water, not air, so if the motor is running but you get no jet action, your most likely air locked and need to prime pump/purge air.
Sep 22, 2008 | Home
Washing Machines Logo
Top Washing Machines Experts
