Question about Kenwood Audio Players & Recorders
Repairing Kenwood DP-1510 CD player drawer - Kenwood Audio Players & Recorders
mjap
  • 107 Answers
SOURCE: Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Posted on Jan 30, 2008
VOTIT
  • 2071 Answers
SOURCE: I-Pod Connection to Kenwood R-SE7
it's better to auxiliary,but if the cord of the optical digital it's ok..
Posted on Jul 25, 2008
  • 31 Answers
SOURCE: Have a Kenwood DP-MA5 home Cd player system.
i supect all it is, is dirt on the laser , but un plug it leave it like that for a while and then plug it back in i doubt it is confused as what you are describing is a dity laser symptom, donot buy a laser cleaner, but clean the laser wih a coton bud or cue tip with no liquids, it is a small glass eye,just twist bud on top, unplug fist laser can damage vision. pleqase leave feedback
Posted on Jul 20, 2009
smarthome2
  • 1114 Answers
SOURCE: i have a kenwood dp-r99 cd player and the cd is stuck
6 or 7 phillips head screws. 2 or 3 across the back and two on each side. Slide the top towards the back then up. You will be able to get to all CD's with the top off. Hope this helps
Posted on Nov 07, 2009
SOURCE: The drawers on the left side that hold 5 cds will
I have the same problem and have just lived with the B deck for over a year. Just now with nothing to lose, I decided to open it up. I don't have a clue about the inner workings, but was on a mission to at least rescue the 3 discs that were held prisoner. I'm happy to say that not only did I rescue my discs, but I'm listening to a disc in tray 2 right now. All the trays now work. I don't know if my disc was jammed in the player or what the problem was, but it seems the act of removing the disc from the deck made all the difference. If you want to try this, take the 6 black screws out (top 2 on rear panel, 2 on left and 2 on right panel) lift the panel straight up to remove it. you'll see the white framework that houses the trays and the play deck near the rear. In retrospect I should have opened up the play deck first since that may have been the source of the problem. I suggest you try that. There are two tiny screws on each side of the framework. Not sure if you need to remove the two screws with the washer heads. I think they just hold the disc clamp head in place. Again, I'm trying to save you unnecessary work, but remove them if it still doesn't come off. Once you get the top of the deck off, you should be able to access your disc. Take it out, then plug in the player to see if the deck starts to operate. I was very surprised. The belts started spinning and I was hearing the startup sounds I hadn't heard in over a year. Hope this helps
Posted on Apr 03, 2010
Model dp-m5560 kenwood cd player won't read discs
It is time for a new player, these players are only repaired under warranty and then it is an exchange unit.
Nov 23, 2016 | Video Game Consoles & Games
Portable cd player DP-R4440
You are describing a common failure of this type of CD player
Aug 22, 2013 | Kenwood portable cd player DP-R4440 User...
Kenwood DP
Take the cover off,To see if the motor to open the drawer is working or not.
Oct 19, 2012 | Audio Players & Recorders
My Kenwood DP-j1070 100 changer is finding cds but not playing anything - there seems to be a spring loose on the loading arm - and not quite sure how to repair - thinking this may be the source of the...
The piece of plastic that held the spring in place probably broke off like mine did. I repaired it by drilling a small hole under the bottom of the slot in the arm and connected it with a piece of solid wire.
Dec 25, 2010 | Kenwood DP-J1070 100-Disc CD Changer
Kenwood stereowith A-58 Amplifier, no manuals, so can't set up
mine does the same and it cost 100 pounds to have the output chips replaced
Apr 08, 2009 | Kenwood Audio Players & Recorders
Kenwood dp-28 cd player jumping cd
My CD player starts to jump after a few minutes and also it doesn't recognise certain CD original disks
Mar 19, 2009 | Kenwood Audio Players & Recorders
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
