Question about Dishwashers
I have a glastender GT-24. It runs a continuous cycle and won't stop. What should I look for to properly have it run a single cycle
  • 7 Answers
SOURCE: water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Posted on Jan 08, 2008
onthejob5130
  • 640 Answers
SOURCE: Whirlpool dishwasher dosen't stop continue to run
defective control board...onthejob
Posted on Jan 31, 2009
  • 105 Answers
SOURCE: Cold water runs continuously at end of cycle
If yo9u were to unplug the machine at that point and the water continues to run in you have a bad water valve. If it stops when yoou unplug it, it may be the timer. Would have to test to see if voltage is present at the valve in the second scenario,. Water valve part# is WH13x10024 @ $51.00
Posted on Apr 08, 2009
  • 127 Answers
SOURCE: the gmax continues to run and won/t stop
if it worked fine and now it has stopped....then there is no adjustment that will fix it. If the fill valve is not shutting off you either need to replace the seal in the valve or get a new fill valve. If the water is leaking past the flapper you will need a new flapper.
Posted on Oct 24, 2009
  • 70 Answers
SOURCE: Dishwasher Hygena Select APL8214/2 - doesn't end cycle properly
1)check the water pressure is ok.
2)any scaling on the rinse arm.(blockage)
3)check the program cycle(rinse)any malfunction.
Posted on Jan 09, 2010
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
The pump runs continuously at low speed.
Are you sure... Continuously?
non stop?
maybe just a long time, and is off when you are not around?
continuously = 24-7
its possible your programmed filter cycle is set for 2 long cycles. ?
Mar 28, 2015 | Pool & Spa
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
Dishwasher continues to run beyond necessary time
most likely the microprocessor has failed
Good Luck!
Feb 20, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
Dec 12, 2008 | Sharper Image SI785 Clock Radio
Won't run through cycle
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
please rate my solution thanks
Jun 30, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Water won't stop running
Jan 08, 2008 | Maytag Performa PAV2200
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
