Question about Lands Phones
Voicemail quick button KX-TS500 - Lands Phones
Voicemail
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voicemail access code and press [SAVE].
Apr 22, 2014 | Panasonic KX-TG4753B DECT 6.0 Plus...
Kx ts500mxb
I need sample & rate of Panasonic Telephone (Model no. KX-TS500 MXB)
Jan 02, 2013 | Panasonic Lands Phones
My panasonic kx-t7431 message light won't light up, I have voicemails but it will not light up, please help!
With the headset off, push the intercomm button or SP-PHONE button, then once you hear the speaker is on do do this.
Push the STAR sign which is * and then number 700 and your four digit extension.
For example ( *7000422).
Nov 30, 2011 | Panasonic KX-T7431 Corded Phone
Hi I have a panasonic KX-T7730 and I need to connect it to my linksys PAP2T Device. but I haven't Voice Over It. can I use this device with KX-T7730?
The 7730 is a Panasonic Analog System phone. It plugs into a Key Service Unit and the line port plugs into the PAP2T device. Model numbers like KXT-A624/824 are examples.
Carl
Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
Is it possible to answer incoming call from kx-t ts 500 pone. we r using KX-T 824 PABX system
Either program your extension to ring or dial 40 when the call comes in.
Carl
Jan 23, 2011 | Panasonic KX-TS500 Corded Phone
How do I transfer a call to voicemail on a Panasonic KX-T7433?
A lot depends on what you dial to get to the voice mail and if it's a Panasonic product. Normall, x165 is the VM. So, you take a spare button, label it VTR (voicemail Transfer) and then press PROGRAM 99, the button and dial 8 165 STORE. Pick up the handset and drop it back down to exit programming mode. The button can be any button, including a PF button (not many features can use it).
Carl
Sep 17, 2010 | Panasonic KX-T7433B Corded Phone
Panasonic KX-T7633 Quick Guide to Voice Mail Options
Going to depend on what type of voice mail. One option to try is while listening to the message try 5* to rewind it or you can type 2 to restart the message.
If this dont work let me know what VM you have.
Jun 15, 2009 | Panasonic KX-T7633 Corded Phone
Number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
Jan 22, 2009 | Panasonic KX-T7730 Corded Phone
Transfer call directly to voicemail
Since you did not mension the phone system type I am assuming it is a Digital like the KX-TD500. You can transfer direct to voicemail if you have a VT ( Voicemail Transfer ) button on your phone. When you want to transfer the party you are talking to, press VT and dial the extension/mailbox number you wish to transfer the call to and hang up to complete the transfer. If you do not have a VT key you can program one of your flexable buttons as a VT key by pressing your PROGRAM button, dial 9 9, press the button to be programmed, dial 8 and the voicemail extension number, press AUTO DIAL/STORE and then press PROGRAM to exit station programming. Good Luck. ....Mike
Aug 04, 2008 | Panasonic KX-T7453 Corded Phone
Lands Phones Logo
37 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
