Question about HP Office Equipment & Supplies
My HP wireless printer wont respond anymore .
It will print a test page prompted by the PC next to it, but wont do anything else. The printer says all is ok and connected. The PC says its functioning normally. When I try to print, PC says "not responding".
SOURCE: HP 7350 printing goes through the motions but nothing
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
Posted on Mar 06, 2009
SOURCE: Can not print at all.
I found a similar error on a Vista 32-bit OS when I tried to print using notepad. There's no dot before dll.
I wouldn't suggest simply deleting the printer from the Control Panel's "Printers and Faxes" folder since that will still leave the printer drivers behind.
Try this instead:
1. Make sure you have the installer CD of the printer, and if not try to download it from the manufacturer's website. Make sure you choose appropriately if you're using Vista or it can cause problems. If you don't do this, Windows won't always download the proper driver for you.
2. Go to Start > Programs (or All Programs) > (Printer Brand) > Uninstall to make sure it's uninstalled, and also check it from the Add/Remove Programs (or Program Features).
3. Restart PC.
4. Use the installer CD, or downloaded installer, to reinstall printer.
5. Test printing from different programs.
If after all of these are done and you still have the same problem (unlikely, but hey, anything can happen), you need to call either the printer or computer technician. Most likely the first.
I tried this process and it printer worked fine.
Posted on Apr 05, 2009
SOURCE: HP PSC1410 wont print and shows offline
I had the same problem. This is what worked for me: I went to the HP website and downloaded the hp Print Diagnostic Utility. Found the problem and fixed it in no time (device manager I believe)... worked beautifully. Hope this helps :-)
Posted on May 20, 2009
SOURCE: HP PSC 1610 All-in-One not printing anything including test page
try this.. i got the same problem before.. and the main problem is the NO MECH MODE.. try pressing the setup button then take the plug out of your printer.. (still pressing the setup button) and put the plug back.. and it will remove the no mech mode.. then you could print like before.. i hope this helps
Posted on Jul 20, 2009
  • 4472 Answers
SOURCE: Canon Pixma ip5200 under Windows 7 - not responding
Did you download the latest drivers from the website? It looks like they were posted this month. I would report the issue. It is quite likely there is a compatibility issue. Have you contacted canon at all about this problem? Once I have more information I can try and assist you further.
Thank you,
Also check out my tip on how to save money using less ink:
Posted on Jan 27, 2010
I have a printer hpphotosmart c4750 wireless all in one but i lost the cd. i can not connect anymore on my computer. how can i get the cd on it? so i can connect it back to my computer. ...
Driver Download here.
Reference Guide
Note: Do NOT connect the USB cable until prompted by the software
1. Unplug your printer from your computer and turn it off.
2. Click drop down button select your OS, click NEXT.
3. Select download, click expand button.
4. Install the downloaded driver, follow on screen instructions and reboot if prompted.
Hopefully this helps.
Thank you for posting..
Jul 08, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Printer will not print anything except test page and wont delete
Possibly, the print spooler needs to be restarted. In Windows, one of the ways to do this is in the Command Prompt window. (Start > Accessories > Command Prompt, right click on the command and choose Run as Administrator in Vista or Win7).
Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. After the last command finishes, restart the computer. Check that the queue is empty and retry printing.
I hope this helps.
Apr 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
When trying to print up an email message ,it only prints half of the page
pleace disconect the power cable from the wall outlet the press and hold the power botton for 20-30 sec then restart and try to print test page
if still it not work then follow this instrution mention from the below URL
and install it and then try to print it should print
even after that if it does not print try and add a printer (deskjet 990c) from the printer page
follow the instructions
1.go to the printers page on ADD A PRINTER next local printer
5.afetr that select HP from the left side deskjet 990c from the right colloumn on next on next
9.after that it will prompt to print a test page and set the printer as default (yes)
10.if the test page prints out
11.try and print the e-mail
it should work
get back to me if you still have problem i will help you
dont forget to vote for me (sincerely be appreciated )
Feb 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
Have Lexmark 1300 for 1 year working good on Vista Home, HP desktop. A couple of days back, the printer would print my doc but I could not print anything else after. Checking the printer queue, it shows...
This may sound radical, but remove the printer entirely from your system. The next time it comes up it will load all printer files again. Next try to print a test page and quickly see if it got out of the que, with the test page. Hope it works for you,
Nov 15, 2009 | HP GX614AA Pavilion A6330F Desktop PC
My deskjet 3550 printed its test sheet and now goes through the motions without printing anything ie ink does not go on paper
make sure that u ink in the cartridges, u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer next use this printer as a default one will give u an option to print a test page on "no" and hit next try to print and check
Nov 12, 2009 | HP DeskJet 3550 InkJet Printer
Printer not responding
Try the HP500Hpgl2 driver, it will work with a USB port.
Dec 13, 2008 | HP DesignJet 450c InkJet Printer
Hp lj1160 wont print
Printers can be tricky. My first suggestion would be to uninstall the printer from the computer. Then to reinstall, I would go to the HP website (they have many pages on installing printers, here is one about network printers at random)
I prefer to use the drivers from the website rather than from the setup disk myself.
Dec 02, 2017 | Office Equipment & Supplies
HP Desk jet 3490
I requere drivers to install my printer 3940
Mar 08, 2007 | HP DeskJet 3940 InkJet Photo Printer
Ben Johnson
