Question about Lands Phones
I looking for r82 memory unit part number h777407a
The number of memory ic is erase
get the Brand and model # of the unit ,buy circuit diagram theire you find the IC number you have looking for.
Dec 28, 2013 | Sharp Televison & Video
Do 4-10 devilles need to have the bias adjusted when replacing tubes?
When replacing the two output tubes you should check the voltage at TP26 or either cathode pin of the power output tubes to ground. Set the bias by adjusting pot R82 to 60mv which is 60 ma across the 1 ohm metering resistor. This coresponds to 30 ma per tube. Changing other tubes requires NO adjustment.
Apr 12, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I am getting a code of E000751-0302, not all the time but is becoming more frequent. I have the codes for the 3200 but this one must be 3220 only as it is not listed. Thanks, Tom
E751 (0302) code is not found in the Service Manual. This code is addressed in Tech Pub TP03 125. The code refers to a memory writing error in the magenta drum unit. Check or replace the magenta drum unit or the Memory board (Memory Board part number is FG3-2345-000.
E751 The connection of the drum unit /toner container is faulty. The mark x indicates color [Y=1, M=2, C=3, K=4]. 000x The connection of the drum unit (at the printer side) is faulty. 100x The connection of the toner container (at the printer side) is faulty. 010x Built-in memory writing error in the drum unit. 110x Built-in memory writing error in the toner container. 020x Built-in memory data error in the drum unit. 120x Built-in memory data error in the toner container. 030x Built-in memory writing error in the drum unit (When the number of retry exceeds the specified value) 130x Built-in memory writing error in the toner container (When the number of retry exceeds the specified value).
Sep 30, 2009 | Canon Office Equipment & Supplies
I have a Fridaire AC window unit about 3 mos old. It just would not work with the buttons, then we unplugged it to reset it, and now it will just beep when we plug it back up and push reset, then it turns...
how long do you leave it unplugged for? try a couple of hours to let any memory voltage dissipate and clear memory, then retry, also does it have any troubleshooting ideas in the owners manual, possibly a certain way of steps to un glitch unit and make operational again
Sep 27, 2009 | Heating & Cooling
Programming a number for memory
Memory
Store up to ten 20-digit numbers in memory for quick dialing.
Storing a Number in Memory
1. Make sure the phone is OFF (not in TALK mode).
2. Press the MEMORY button.
3. Press a number (0-9) to store the dialed number in that memory location.
4. Press the MEMORY button again.
5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm.
6. To enter another number in a different memory location, return to step 1 and repeat the process.
Nov 03, 2007 | Uniden Cordless Phone
Storing numbers in memory
Call conairphone, they will tell you over the phone how to sotre numbers. You can find their number by doing an online search. If you have an old model phone follow these steps. You have to make sure your batteries are working. Leave phone in cradle - press and release store button - dial the number - press and release store button again - press the button you want your number stored.
May 07, 2007 | Conairphone CID 244
Erasing some or all stored numbers from memory
Im sorry I dont know buit you must have an instruction manual that can assist you and if not maybe a tech assist # in the papers you got with this unit as everything I look up fopr this unit says discontinued!! sorry man I've tryed now for two Days and a friend tryed his sources too to no avail.. Sorry >:{
Apr 10, 2006 | TT Systems 3460 2.4GHz Phone (IBM-3460)
Lands Phones Logo
42 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
