Question about Cell Phones
Hi I want to give my dad my old bb z30. Tried doing a security wipe to reset but it tskes me to enter bb id and password. I had to reset password but it wont work on my device
Gil D
  • 217 Answers
SOURCE: last night I tried to use my BB=8330, but it ask
try to reset again.if not full flashing is necessary in order to work it properly.if you are here in the philippines you can contact w/ me thru this address:exel_bernardo@yahoo.com.thanks
Posted on Jul 07, 2009
  • 55 Answers
SOURCE: I use a security code on my BB Curve 8330. I
I had the same problem a while ago you need to set the "key stores" password you do this by going to options select security the select key stores and when your in there hit the blackberry button on your keypad and then select "change password" then enter your password you want then you should be good to go next time you connect your phone to your computer because you just enter that password you did there on the computer and then you're all done!
Kyle
Posted on Jul 09, 2009
  • 215 Answers
SOURCE: need to recover password for a toshiba satallite A305-S6909
Try the following procedure, may be it can help you.
Restart computer in safe mode (direct after Bios screen as windows OS going to load press repeatedly F8 key and choose Safe Mode).
In safe mode when Welcome Screen appears you'll get option for Administrator account along with your own account. Try to login to administrator account as they are mostly not password protected. If sucessful then go to control panel ->user accounts and click to enter into password protected account. Change the password for your account. close all windows and restart in normal mode.
If the administrator account is password protected too, then go to:
http://home.eunet.no/~pnordahl/ntpasswd/ and read the procedure for password recovery.
Posted on Sep 10, 2009
  • 94 Answers
SOURCE: tried to rest my password entered old password
There is only one way, you have to open up the computer and remove the cmos battery, it looks like a watch battery with shrink plastic around battery with a red and black wire that plugs into the motherboard, this will reset the password, it is a little secret trick, techs use, you may be able to get to the battery by removing the little back lid that is on the underside of the laptop, sometimes it is located there, if not, you need to carefully remove, pry up the plastic strip above keyboard, then you will see the few screws that attach the key board, under key board you should be able to locate battery, remove,disconnect it for 30 seconds then replace it, and you just reset password so you can get in your computer, good luck. all else fails go to best buy and you can buy a password recovery software.
Posted on Nov 29, 2009
muleskinner2
  • 270 Answers
SOURCE: Enter DEPT.ID & DEPT.ID Password
You will have to reset/clear the password. This WILL REMOVE all passwords setup in Dept ID Management. Go into Service mode by pressing the Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, PWD-CLR, Then Ok. You may also use the arrow keys on the display to get to PWD-CLR. Then the RESET key or maybe power down the equipment.
Posted on Jun 21, 2011
How do I retrieve my blackberry username and my blackberry id?
If you enter incorrect BB.ID details you will see the option that says "forgot password" Click on this and follow the instructions that will prompt you for your email address. If you cannot complete this process, then it means you have a BBerry device that is not yours. RIM saves and associate your blackberry ID with your email address at the time of initial registration. Your email is the gateway to retreiving you BBerry ID. If not, please return the handset to it's rightful owner.
Dec 06, 2014 | BlackBerry Z30
Hey guys . I have a blackberry mob and it was working well . I have changed my blackberry id and then bbm doesn't work since I did that . I removed it many times and reinstalled it but it doesn't work
Greetings,
Try going to this web page :
Forgot my BlackBerry ID Password And Recovery Question
and check the last reply on the page:
Re: Forgot my BlackBerry ID Password And Recovery Question.
Start first with these please:
  • KB28685 How to reset the BlackBerry ID password using the password recovery question
  • KB32111 "The link is no longer valid." is encountered when attempting to reset a BlackBerry ID password
  • KB26361 How to change or reset the BlackBerry ID password
  • KB28111 Unable to reset BlackBerry ID password when using a BlackBerry hosted email address
  • KB28232 BlackBerry ID reset email is not being delivered to the associated mailbox
If you have forgotten your BB ID credentials AND have non-BB access (e.g., Outlook, webmail, etc.) to the email account that is currently configured to your BB ID account, then those instructions should allow you to recover access to your BB ID account.
However, if you do not have access to that email account, then your challenge is much greater, and you have a choice to make depending on your circumstances:
  1. If you have no AppWorld records that you require to retain (e.g., purchase records for apps), then simply abandon the BB ID and create a new one. To do so, however, does require a device WIPE:
    • KB26694 How to change the BlackBerry ID on a BlackBerry PlayBook tablet or BlackBerry smartphone
  2. But, if you do have AppWorld records that you must keep, then you require human intervention. To receive that, you must ring up your mobile service provider and convince them to escalate your case up to BlackBerry. Further, you must convince BlackBerry to provide you with a solution -- which likely will either be resetting your current BB ID so that you can again access it or having you create a new BBID and they will manually move your purchase records over. Note that I have no idea if they will be willing to do this, but there is no other way that I know of to retain your prior AppWorld purchase records.
Oct 22, 2014 | RIM BlackBerry Curve 3G 9300 Cell Phone
Were can i get my blacberry id passwordundefined
You cannot ...sorry.
Blacberry was DESIGNED securely. You get 10 chances then WIPE !!
BBs are very secure -- only the user created password can unlock the BB. There is no "master" or "override" password to do so...only the user created password can do so.
But, you may be in luck anyway...refer:
  • KB05099 Steps to take before selling or after buying a previously owned BlackBerry smartphone
Failing the password the maximum times will initiate an on-device WIPE, which is included in those important instructions. But, the other steps within those instructions are likewise important to conduct...by both the seller and the buyer. Not properly completing ALL of the instructions risks rendering the BB not fully usable by the buyer (you).
Sep 18, 2014 | RIM BlackBerry Cell Phones
Password Promblems
You might have forget your password
you can reset your password by using these three options
1. reset your password using alternate email id
2. reset your password using security questions
3. reset your password using your phone number
Feb 22, 2014 | gmail.com
How do I reset my blackberry ID
you have to do a security wipe from the settings...then after the security wipe...you can setup your blackberry using a different bb ID
Oct 24, 2013 | Blackberry Cell Phones
I forget yahoo password and tried for secret question but i cant retrive please the password
you need to login to login page of yahoo mail and click on I can't access my account
under user ID and password box, then select forgot the password and
click on next, then enter your yahoo ID and enter the code which would blink there
and click on next and then it would ask you 2 security questions so click on forgot the answers and you need to give your alternate email ID there and you will get an email in your account from where you can reset the password for yahoo mail ID.
May 13, 2010 | Yahoo Messenger
Can i reset forgotten password on BB curve if not enabled
Yes, but you would have to enter the wrong password 10x - Caution - this will wipe your BB of all saved data.
Or can contact your cell provider and see if they can reset your password if not and your BB is issued to you via your Company than you can have your BB Administrator reset your BB password.
Hope this helps.
Oct 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
Bb 8310
the password i kept typin in was wrong on my blackberry curve, so it started wiping everything and now it says JUM error 513 and it wont get into my phone,the only way it turns off is by taking the battery off,i tried reseting it and it goes to the same screen? what can i do to get in my phone?
Aug 11, 2008 | AT&T Blackberry Curve 8300 Smartphone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
