Can I get drivers and software for ASK4000 and ASK2000 printers to run on windows 10.1?
My Windows 10 computer can no longer find my printer.
try removing printer from control panel - printer and devices (right click start icon bottom left corner - select control or settings from menu - I don't use windows 10 much !)
then right click on start and select system . Note the Windows operating system and if it is 64 bit whether it is windows 10s or windows home edition .
Then go back to hp driver download web site and download the matching driver with your printer model and operating system.
Run driver install program you just downloaded to install driver and it should find your hp printer and set it up in windows.
Feb 21, 2018 | HP Office Equipment & Supplies
How do I instal Epson TM-200 plus printer on Windows 10 ?
That is because Win10 does not support your printer. It is too old.
Sep 21, 2017 | Epson Office Equipment & Supplies
Is Canon Pixma MX410 compatible with Windows 10 Home OS?
The MX410 is fully supported by Canon for Windows 10. You can find the available drivers for the MX410 here: . You will need to confirm weather you have the 64-bit (x64) or the now rarer 32-bit version of Windows 10 Home. The basic drivers are listed under the Driver tab. The MP Navigator program is under the Software header. The full software is useful, for many users.
Note: the available software does not include any third-party software that may be on the original discs that came with the all-in-one.
I hope this helps.
Apr 19, 2017 | Canon Office Equipment & Supplies
Installed Windows 10 from Windows 7 and now my Pixma MG2900 printer doesnt work
There was a new driver package released on July 25 to include Windows 10. Here is the link for the driver download. Hope this helps!
MG2900 series Full Driver Software Package Windows 10 10 x64 8 1 8 1 x64 8...
Oct 23, 2015 | Office Equipment & Supplies
How do you replace ask2000 printhead
Normally you can follow these given steps..It can be different for different model.....
Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place.
The print carriage will move to the center of the unit. After the print carriage stops, release the gray print carriage latch and lift upward to access the printheads.
Remove the old printhead by lifting the printhead handle and pulling upward.
Being careful to touch only the black plastic remove the new printhead from the packaging and gently remove the plastic tape.
Using the printhead handle, push the new printhead firmly down into the appropriate slot; matching the color on the top of the printhead to the color on the printhead carriage.
Move the print carriage latch down, and make sure the loops catch the hooks. Snap the latch into place, and close the print carriage access door.
After the message to align the printheads appears in the front panel display, press Enter . A page prints to confirm alignment.
If you need any kind of technical assistance you can contact support cell at
Dec 06, 2012 | FUJIFILM Ask2000 Thermal Photo Printer
How can i turn on the print spooler on my dell 922?
Please follow this steps
1. Disconnect the USB cable from the computer.
2. You need to stop the printer spooler service as follows:
a. Click Start.
b. Type ‘cmd’ in the Start Search box. -Search results should appear-
d. Right‐click on ‘cmd’ in the search results, and then select Run as Administrator.-The command window will appear- (black window)
e. Type ‘net stop spooler’ into the command window and press <ENTER>.-The Print Spooler service should now be stopped-
Next, delete the printer drivers from the system as follows:
---Warning--- These steps will remove drivers for ALL printers installed on the system.
1) Click Start.
2) In the Start Search box, type ‘C:\Windows\System32\Spool\Drivers\w32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
---NOTE--- There may be some files that will not delete because they are being used by Windows.
Click on the Ignore button to bypass deleting these files.
With the drivers uninstalled we now remove the Dell printer software.
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
You need to delete the Dell printer from the printers list.
1) Click Start
2) In the search bar type “Printers” and press <Enter>
3) Select any and all Dell printers and press <Delete>
Now delete any OLD drivers from the Server Properties Window.
1) Click Start
2) Type Printers into the search bar and press <Enter>
3) Press <ALT> to bring up the file menu.
4) Select Run As Administrator then Server Properties.
5) if the UAC window appears just click Continue.
6) Click on the Drivers tab.
7) Select any Dell printer drivers listed.
8) Click Remove, and then select Remove Driver and Driver Package.
9) Select Yes to confirm removal of the driver.
10) The system will now scan to see if it can remove the driver.
11) Once it has finished scanning click on Delete.
-Repeat the last 11 steps for each Dell printer driver that is installed.
At this point, you should be able to install the latest printer software for Vista from and be able to print successfully.
-NOTE- It’s been reported that some driver installations in Vista can take up to 10 minutes. Be patient and please wait for the driver to fully installed.
Hope this steps will resolve the problem
Sep 21, 2009 | Dell 922 All-In-One InkJet Printer
Canon LBP 2900 drivers 64 bit?
Now official drivers from CANON for lpb2900 win7 x64 !
Jul 17, 2009 | Canon LASER SHOT LBP-2900 Printer
27 people viewed this question
