Question about Bunn Coffee Makers & Espresso Machines
My bunn coffee maker leaks at the bottom. Can you tell me what to do
    Master:
  • Bunn Master
  • 577 Answers
Okay no model given,
* Pour over brewers only leak if over filled (more than a pot). If it leaks just sitting there then there is a hole in the tank. Call for service or replace.
* Commercial machines like CW, CWTF, Single, Dual, Urns, are plumbed into a water line. Leaks may come from the water line, Tank, or urn.
* If the water leak is clear and not hot then it's the water inlet line.
* If it's hot then the heater is leaking,
* If it's coffee colored then it's the urn where the coffee is being brewed.
* In All cases call your vendor for service as this is a hazardous situation. Unplug or turn off the power to the unit. It should be on a large throw switch near any large brewer. Have maintenance turn off the breaker and leave of till the vendor can service.
Aloha, ukeboy57
Posted on Jan 20, 2018
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
  • 189 Answers
SOURCE: My Bunn coffee maker leaks out of the bottom
If you will call Bunn Customer Service, there is a seal kit that can be sent out to fix the leaking problem you are experiencing.
Posted on Jun 02, 2010
Jun 01, 2010 | Bunn 10 Cup Home Coffee Brewer
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Oct 24, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
My bunn leaks at the bottom. I have always bought a bunn coffee maker and everyone of them have leaked. Why?
A seal/gasket can go bad. If you will get the model and code date and contact customer service, we will be happy to assist you in resolving this problem.
Sep 26, 2009 | Bunn 10 Cup Home Coffee Brewer
Jan 12, 2009 | Bunn VPR Coffee Maker
Bunn Coffee maker leaking out of the bottom of the coffee maker when the coffee maker is not making coffee.
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
Dec 10, 2008 | Bunn NHB Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
