Question about Alpine Car Audio & Video
Hello, I have an Alpine CDE-SXM145BT with a problem. had to replace battery in car and lost power to the radio now my satellite radio won't tune past 00-01.
SOURCE: SET CLOCL
Hold in title button on the bottom right hand corner
Posted on Apr 16, 2008
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
SOURCE: Connecting High Speed IPOD Cable to Alpin CDE-9874
Best Buy solved my problem.
Posted on Oct 02, 2008
Eagleeyes
  • 199 Answers
SOURCE: Alpine CDE-7859 **** Preseting the radio stations?****
http://www.alpine-electronics.co.uk/index.php?id=915&L=&manualsearch=CDM-7859RB
User Guide can be downloaded from here
Mark
Posted on Nov 17, 2008
Char1ieJ
  • 100 Answers
SOURCE: how do I set the clock in Alpine CDE-9872 CD receiver?
From the Owners Manual for the CDE-9872:
FixYa won't allow images larger than 150k, so that's why this is a little blurry.
I hope this helps! Please post rating, if it does.
Regards,
Char1ieJ
Posted on Nov 18, 2008
I have an Alpine CDE-SXM145BT car stereo. that will not play Bluetooth devices.
Have you had the battery removed at any time before this happened or been jump started ?
Apr 09, 2017 | Alpine Car Audio & Video
CHECK TUNER on Sirius XM
Ours was corrected by removing the faceplate and holding in the small red reset button that is located about halfway across the front
Jan 16, 2014 | Alpine CDE-SXM145BT Advanced Bluetooth CD...
Does not power on
Check the fuse in the fuse box of your car and if that doesn't help there is a fuse on the back of the alpine unit. And if this doesn't fix the problem then most likely you have a bad unit.
Nov 03, 2013 | Alpine CDE-SXM145BT Bluetooth CD/SiriusXM...
Is there an adapter I can purchase to be able to play an IPOD with my alpine cde 9841 car cd receiver stereo?
Your headunit doesn't have the option of a plug i Ipod cable, The only way to use it with your stereo is to get an FM Transmitter and you tune into the ipod through the radio.
Mar 06, 2012 | Alpine CDE-9841 CD Player
How do I set the time on an alpine cd/radio reciever 7874?
Check out the owners manual, here's the link to copy and paste in your browser search.
www.crutchfield.com/ISEO-rgbtcspd/p_500CDE7870/Alpine-CDE-7870.html?c=3 - 47k
Mar 26, 2009 | Alpine CDE-7870 CD Player
Cannot operate Alpine CDE 9881
Hello!
Hopefully this will help you out.  The manual for the 9881 can be gotten here:  http://vault.alpine-usa.com/products/documents/OM_CDE-9881.PDF
Copy the entire line into your browser, and you will have it.  Don't forget to save it to your system.  It is in PDF format, so if you don't have a reader, pick up one for free here: http://www.adobe.com/
Good luck with the "new" car and radio!
Ken
Jan 08, 2009 | Alpine CDE-9881 CD Player
Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
Nov 20, 2008 | Alpine CDE-7853
Car Audio & Video Logo
32 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
