Question about Epson Office Equipment & Supplies
I'm expecting the exactly same problem on my epson stylus pro 7890 i've just remplaced a bamper and when i restart the printer todays all my cartridges are error. the exact error
  • 300 Answers
SOURCE: EPSON STYLUS PRO 10000
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
Posted on Aug 30, 2008
cns assoc
  • 677 Answers
SOURCE: EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
SOURCE: Epson Stylus Pro 4000 got the 0001001B error
When determining a solution for an error, always look to what changes you instituted just prior to the error. In my case, I switched from FW to USB. That brought on the 0001001b head driver (tg) temperature error. When I switched back to FW, the error went away and the SP4000 display reads "Ready"
Posted on Aug 29, 2010
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
markfreedman
  • 312 Answers
SOURCE: When I change the ink
I also have a an Epson that takes the #69 cartridge. Whether or not I solve your issue, I suggest you call Epson and tell them about this issue. What you think and a piece of your mind. I've done it and they replaced my printer. I called their consumer relations relations and explained to them that I have owned Epson Printers for years which is true. That any time of the day or night I can find a 10 your old Epson dot matrix printer on Ebay, get it in the mail and it would work perfectly and be more dependable then what I have sitting in front of me. I would remind them that they have a great deal of experience building printers and ask them to restore my faith in them.
Now that I have soap boxed, lets get down to your printer.
The Epson has a circuit board installed in every cartridge itself. It is designed to shut down the printer when it is out of ink and to thwart any attempts to refill it. Your detection system is obviously malfunctioning.
This is what I would do, for what it is worth it sometimes works.
Using the Epson maintenance utility to change cartridges I would do the following:
1 Remove the cartridge
2 Remove all the rest of the cartridges
3 With a strong flashlight, look inside where the spring contact that the cartridges fit against in the head and brush out any possible debris you can find with an old toothbrush. You may want to put a small amount of rubbing alcohol or vodka (expensive rubbing alcohol) on the brush and wipe it over the contacts lightly. DON'T USE COTTON SWAB OR PAPER TOWEL AS PAPER WILL EASILY GET LODGED INTO THE MACHINE.
4 Use a cotton swab dipped in alcohol to remove any oily residue that may be on your four cartridges. JUST WIPE ONCE AND DRY WITH CLEAN PAPER TOWEL IMMEDIATELY.
5 INSTALL ALL FOUR CARTRIDGES INTO THE MACHINE.
6 RUN THE REST OF THE INSTALL UTILITY DOING RECHARGE AND CLEANING ACTIONS AS USUAL.
Tell me what happened.
I have had it work when I have removed all four cartridges, even though I am only changing one of them.
I hope this has helped.
Best Regards,
Mark
Posted on Jan 04, 2011
On the screen of my Epson Stylus Pro 4800 InkJet Printer came a message update F/W
it's asking if you want to update firmware, firmware is the softer internal to the printer that tells it how to work / behave / communicate. this is sometimes updated by the manufacturer.
sounds like you are in the service menu...if you press the cancel buttons, or shut it down and restart the printer it should return to normal operations.
Jan 11, 2016 | Epson Stylus Pro 4800 InkJet Printer
I have the Epson Stylus Pro 3880. Up till a few weeks ago all was well, the today, it decided not to print out the black areas of my shots. I've check the inks, the heads all is well. HELP
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 02, 2012 | Epson Stylus Pro 3880 InkJet Plotter...
I lost my cd for installation for my epson stylus nx130/tx130 series printer
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
May 25, 2012 | Office Equipment & Supplies
My epson stylus pro3800 says it's off line, even though it's not. I tried turning off the power and reconnecting. I restarted my Mac.
Hi
I might be corrupted printer driver. Try to delete the old printer icon and re add again the printer. Regards
Jul 04, 2011 | Epson Stylus Pro 3800 InkJet Printer
How to remove and clean epson stylus pro 7000 printer head its cloged
Welcome to FixYa!
If you have not used your printer for a long time, the print head nozzles may be clogged. Perform a nozzle check and clean the print heads.
Use the Epson Printer Utilities to do a nozzle check and to clean the printer head.
Reference Manual of Epson Stylus Pro 7500 InkJet Printer:
http://files.support.epson.com/htmldocs/pro75_/pro75_u1/INDEX.HTM
Comments and rates are appreaciated.
Thanks for using FixYa.
Jas
Feb 23, 2011 | Epson Stylus Pro 7500 InkJet Printer
Cannot instal Epson Stylus D92 with my windows xp pro
Uninstall printer driver if you have installed before. Restart computer. Power on printer, connect printer to computer. Is found new hardware?
Oct 18, 2009 | Epson Stylus D92 InkJet Photo Printer
Need parts diagram and/or disassembly instructions
Here's a link to/for a free downloadable service manual (in pdf format), which contains disassembly information for the EPSON Stylus CX4100/CX4200/CX4700/CX4800/DX4200/DX4800/DX4850: http://www.opweb.de/model.php?id=4029. I've already downloaded it (today, 7/10/2012), and have been perusing the disassembly instructions which I also need and which appear to be quite explanatory.
Jul 14, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson 7800 Service call error 0010014
The same thing happened to me and was solved by putting a new cartridge. Someone told me that it's something about the cartidge and it was my solution.
Apr 10, 2009 | Epson Stylus Pro 7800 InkJet Printer
62 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
