I'm looking for a charger for a MDP-1770 portable DVD
StuntJay20
  • 24 Answers
SOURCE: Charger for Mintek portable dvd player 1810
eBay has a few charges for your portable dvd player.
Posted on Mar 19, 2008
SOURCE: MINTEK MDP-1770 PORTABLE DVD PLAYER
did u find a solution yet because i am having the same problem?
Posted on Jun 11, 2008
  • 17 Answers
SOURCE: I want to know if
yes,is same
Posted on Aug 11, 2008
SOURCE: Mintek MDP-1770 Portable DVD is not powering up
Change the battery
Posted on Aug 12, 2008
  • 814 Answers
SOURCE: I have sound but no picture, can you help
Please give more information, on how you found the problem. Have you tried the video output connected to another monitor to see if the video processor circuits are still functional. You can do this by using cables to the video output of the dvd player to the input of your television. Usually Three wire connections. The yellow connector is for the video and the red and white connectors are for the audio. Make these connections and use your television on a alternative signal source input. This is usually a function button on the television or the remote control. The function is usually labeled input. You can find the correct set-up information with pictures in the owners manuals of the products. If after testing the video ouput from the dvd player. You find that you do have output, then you may have a connection problem between the main board and the LCD screen. These connectors are usually ribbon cables and are a yellow or golden color. They are connected by a clamping connector. The connector is usually released by using a small screw driver to release the clamping device. You can check the connector and see if it looks like it still working. If the connector looks crimped,torn or bent badly it may need replacement. If they look ok , then you may want to use some contact cleaner to clean the connection points and the connector. You can do this by spraying a small amount of contact cleaner on a cotton swab. Take the swab and wipe the connector, cleaning the connection points and then use a small brush with a small amount of contact cleaner to clean the connector. You can also use a can of compressed air to blow all dust and debris from the connector and the circuit board. Make sure to clean all areas of the board as dust and dirt act as a heat blanket and cause overheating problems on the ciricuit board. If all of this seems over your head. Have a friend help you. Or take it to a repair shop for evaluation. There are many helpful videos on you tube that can show you how to do the disassembly and cleaning of the player . Look under cleaning and repairing portable dvd players. If you have a vidoe processor failure, then it may not be repairable. The expense may be more than the cost of just replacing the dvd player. I hope this information helps you with your problem.
Posted on May 29, 2009
Where do i find an owners manual
Hi Joann,
I did a little research. First of all Ebay has 2 different listings.
1st is a NON working Mintek MDP-1770 same as your's that has all power adapters including the car charger, but no manual. If you get on Ebay type in this # in the search bar.. 271309709718
That is the item # and will sell for $8.99 plus $9.03 S/H. 2nd also on Ebay, is a brand new in the box with ALL extra's and manual for $22.99 plus $14.99 s/h. It is item # 141112619100. Either should work as you would also be getting an extra battery.
Good Luck!
Michelle
Nov 10, 2013 | Mintek MDP-1770 Portable DVD Player
Tip
Regional code change for MDP-1770 Portable DVD Player
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
Lost ac adapter to MDP-1770 where can I GET
Jeanie, I happen to have a MDP-1770 and it's not working. We only used it maybe once or twice if that. So everything is like new, you are more than welcome to have the AC unit I have along with whatever else you need. contact me at msjune2u@gmail.com
Mar 20, 2010 | Mintek MDP-1770 Portable DVD Player
Need user manual for mintek dvd player MDP 1770
stop asking me questions im trying to go to sleep now go somewhere
Apr 04, 2009 | Mintek MDP-1770 Portable DVD Player
Mar 19, 2008 | Mintek DVD-1810 Portable DVD Player \
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
