Question about Home
I need instructions for BOCH freezer emy32clc
Knob of coffee pot knocked off, Villeroy and boch switch 3, can I find a replacement without buying full pot
www.villeroy-boch.com/.../faq.html?&...en..
https://pro.villeroy-boch.com/en/.../technical-data.html
Jul 05, 2014 | VILLEROY AND BOCH USA Villeroy n Boch...
Tank Cover
online by asking same question on web.
Mar 31, 2014 | Villeroy & Boch Villeroy-Boch Colani...
Villeroy & Boch flush tank doesnt get water
Hi pervana....
You have an obstruction in your ballcock/inlet valve or the ballcock/inlet valve is malfunctioning and is need of replacement.
Try to move the float up and down inside of the bowl, this may loosen the valve and allow water to enter the tank.
If this does not solve your problem then you will need to replace the ballcock/inlet valve.
Free Answer...Please take time to rate me
May 16, 2011 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
Hi i am looking for Villeroy & Boch seat product no: (9955 S1 01). Kindly, provide me Quotation
V & B US customer service number used to be 877-505-5350 it has been a while since I used it, but they were very helpful when I did. Hope this helps.
May 11, 2010 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
My Villeroy and boch toilet's water level inside the toilet is always low. I was seeing if there was a way to increase the level inside the toilet, not the tank.
V & B toll free number was 877-505-5350. I hane only worked on one in 25 years and they were very helpful. Hope this gets you in the right direction.
Feb 09, 2010 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
How can I replace toilet seat for the Subway model? It does not seem accessible without taking the toliet down
There are little toggle bolts hidden at the back underneath the seat. The location and the image is shown in this PDF:
http://www.villeroy-boch.com/fileadmin/picdb/produkte/bad/daten/XX/9955Q1.PDF
It's difficult to describe how to disconnect them but pretty easy to figure out just fiddling with them once you find them.
Good luck.
Aug 02, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
My V and B toilet suddenly stopped flushing today, what's the problem?
It won't drain? Is the tank draining? Is the water turned off? Or is it just plugged up?
Jun 19, 2009 | Villeroy & Boch 6610 11 Subway...
Villeroy & boch flush mechenism needs to be replaced
This problem is either two things:
1/ The water inlet valve is letting by and going down the overflow pipe. (Connected to the main centre column). You can check this by taking off the lid off.
2/ Centre column seal at the base is letting by. You can unclick the centre column by pushing the two paddles either side.
Then lift out the centre column and check the grey washer at the base. You can turn this washer around and see if this solves - if not the column has probably has a part snap off.
You can get spares here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
May 27, 2009 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
