Connecting & pairing on wifi/alexa
I received a fire stick and an alexa remote...having hard time getting going??
4 Suggested Answers
  • 2559 Answers
SOURCE: Re fire stick use..screen says home is currently unavailable...we are unable to connect to Amazon services...check your internet connection My wifi is fine...why isn't tv getting a connection...thx
Contact amazon technical support. There may be some changes needed to make it work.
Posted on Nov 01, 2016
  • 15483 Answers
SOURCE: how to install alexa on amazon fire tv stick?
does your fire stick have voice command option if not alexa will not work
Posted on Jul 13, 2017
tech786u
  • 439 Answers
SOURCE: Setting up my echo.
Call for expert assistance +1(518)348-9393 Thank You
Posted on Jul 16, 2017
My fire stick remote won’t respond to Alexa commands from remote
hi Douglas298.
this is all i could find.
Fire TV Remote NOT Responding / Syncing / Connecting: SOLVED I've changed the Fire TV Voice Remote control batteries 5 times already but it still keeps disconnecting and now it's gone completely dead! Update 08/02/17: The most probable cause for your Fire TV remote not working is going to be the batteries. I know, you're thinking I've already changed the batteries twice already. The Fire TV remote is a fickle beast and only likes brand new fully charged batteries before it will re-connect to your Fire TV box. I've tried switching in batteries from other devices that are all working fine, but without any success. Brand new batteries are the key for this power hungry remote.
Has your Amazon Fire TV Box or Fire TV Stick become slow? See my Fire TV Slowdown Solution here.
This need for new batteries seems to be especially true when your Fire TV box is next to a complicated TV setup with AV, Speakers, WiFi Router all next to each other.
AMAZON FIRE TV 4K
AMAZON FIRE TV STICK
If you've tried brand new out of the packet batteries and it's still not working then you might have the same issue I had below. Don't forget to ask any questions you might have in the comments beneath this article.
Update: You can now control you Fire TV Device with the Amazon Echo & Amazon Echo Dot
If you've felt the annoyance of your Fire TV Voice Remote suddenly not connecting then I know how you feel. I've owned a Fire TV since October 2014 and up to now it's handled everything I've thrown at it. This is until one day last week when the remote suddenly kept disconnecting then died completely showing no signs of life.
I went through an array of different fixes to try and get it to work again but then finally I had a brainwave and managed to bring the remote back to life. It wasn't through trawling internet blogs and YouTube videos that I found this solution, it was actually from inspecting the remote more carefully. No, it wasn't Amazon's fault for building inferior products it was actually my own fault and partly the fault of cheap pound stores that litter the UK.
When I took the battery compartment off the Fire TV remote it looked completely normal. It wasn't until I raised the remote up to eye level that I noticed that there was a slight chalky residue on the connectors of the battery compartment. It then dawned on me as I looked across the room at a packet cheap pound shop batteries. One of the cheap batteries had leaked battery acid on to the Fire TV remote connectors blocking the current from getting through.
How to use your Fire TV when the remote won't turn on?
Luckily, Amazon have an App for that called Amazon Fire TV Remote that is available in the Android App Store and the Apple App Store. You can then control the Fire TV using the app and proceed to the next step below.
How to check if your Fire TV remote is connected to your Fire TV?
To see if your Fire TV remote is connecting to your Fire TV box or dongle you need to head to the settings menu.
  1. Settings > Controllers and Bluetooth Devices.
  2. Amazon Fire TV Remotes
This will show you what devices are currently paired and from here you can see if your remote is connecting. In my case when fiddling with the batteries my remote would appear here for a few minutes then disappear.
If all else fails, you can get an official Amazon FireTV Remote replacement.
The Solution
I took a flat head screwdriver and gently scraped the connectors of the Remote at each end. Wiping the residue off with a dry cloth as I scraped. The connector should look shiny and new again at the end of this process. I placed the batteries back in and the remote connected again straight away.
I've had no problems with the remote since and I guess the moral of the story is sometimes you get what you pay for... utter leaky batteries this time.
Fire TV Quick Tips
  1. Hold down the Select button for 5 seconds to put the remote into pair mode.
  2. Hold down the Select + Play buttons together for 5 seconds to Restart the device.
  3. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in.
  4. or try this link.
fire stick remote wont respond to Alexa commands from remote Google Search
Nov 29, 2017 | Televison & Video
Do I need to buy music to ply it on Alexa or is there another way of downloading
hi John.
this is what i found on the internet.
if this does not help you out go to the link at the bottom and see if it helps you out.
Ways to Listen to Music & Media on Alexa You can use Alexa to stream music, podcasts, audiobooks, and more from popular streaming services or from your phone or tablet over Bluetooth.You can also upload your personal music collection to your music library on Amazon and then stream your music through your Alexa device.
Link a Third-Party Music Service to Alexa.
Note: Spotify Premium on Alexa supports Spotify Connect, which allows you to play music on your Alexa device and use the Spotify app on your phone or tablet as a remote. Alexa on Fire TV devices does not support Spotify Connect.
My Music on Amazon from your computer. After you upload your music, you can ask Alexa to play your music and control playback with simple voice commands.You can upload up to 250 songs to My Music for free. To upload up to 250,000 songs, you can switch to an Amazon Music storage subscription. To learn more, go to Change Your Amazon Music Storage Subscription.
Note: Purchases from the Digital Music Store as well as tracks from AutoRip-eligible CDs and vinyl records purchased on Amazon do not count towards the 250 song limit.
Play Music on Multiple Echo Devices. Pair Your Mobile Device with Your Echo Device
  • Pair Your Mobile Device with Echo Show
  • Connect Your Echo Device to Bluetooth Speakers
  • Note: Voice control is not supported for Mac OS X devices (such as MacBook Air) or on other Alexa-enabled products. When using Multi-Room Music, Bluetooth connections (such as from mobile phones, or to external Bluetooth speakers) will be disconnected.
    Do need to buy music to ply it on Alexa or is there another way of...
    Nov 20, 2017 | Computers & Internet
    I installed my Fire Stick yesterday when I try to use Alexa it says it can not condect. What do I do ?
    Make sure the Firestick is connected to your network correctly
    Make sure the Remote is paired to the firestick
    Mar 02, 2017 | Televison & Video
    Connecting fire stick to tv. i am a prime member with amazon
    Setting up Amazon Fire TV Stick hardware
    1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
    2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
    3. Next, turn on your TV and switch the input to the right HDMI port
    4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
    5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
    6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
    7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
    8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
    9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
    Now you've set your Fire TV Stick up, here's how to install Kodi on it.
    How to set up your Amazon Fire TV Stick
    Dec 23, 2016 | Televison & Video
    How do i know alexa remote for fire stick will work in my area
    need to notify manufacturer for compatibility or regional area of operation
    Oct 15, 2016 | Amazon Fire TV Stick with Alexa Voice...
    Why can't I register it?
    Fire tv stick can't register - Amazon.com
    https://www.amazon.com/gp/.../ref=cs_hc_g_tv?...
    Amazon.com, Inc.Received my new fire tv stick today. I'm able to get past the wifi connection screen. But registering it with my Amazon account is I'm possible. Tried over 50 times ...
    Amazon.com Help: Basic Troubleshooting for Amazon Fire TV
    https://www.amazon.com/gp/help/.../display.html?...
    Amazon.com, Inc.Make sure your Amazon Fire TV device is registered to your preferred Amazonaccount. To verify your registration ... Can't Access External Storage. Note: External storage options are not available for Fire TV Stick. First, make sure you're using ...
    Amazon.com Help: Can't Connect to Wi-Fi
    Dec 26, 2015 | Amazon Fire TV Stick
    Televison & Video Logo
    Top Televison & Video Experts
