Question about The Computers & Internet
Lenox Model CD-1493 Can't get the case apart for service. I removed the 6 indicated screws and the antenna screw, but the back seems to be still attached to the front. I can't find out where. Help
SOURCE: crank is stripped?
There are 6 screws in total. One is hidden behind the label on the back in the centre. Also one is in the middle of the battery compartment. Once all six are removed one will most likely find that one or more of the gear(s) is broken.
Posted on Sep 03, 2007
SOURCE: Navman iCN 520N disassembly
press the top and bottom theres clips on the top and bottom
Posted on Mar 25, 2008
rubyisred
  • 28 Answers
SOURCE: Samsung sgh-a707 repair
Did you find the two screws located under the two round rubber dics located at the back top of the cell phone? If you remove the two round rubber discs you will find screws under them. Once you remove those screws you will be able to remove the one plastic frame. Be careful, there are two places that you will need to disconnect in order to completely remove the insides from the frame. If they are not disconnected you will not be able to remove the main brain of the phone. The 1st one is easy to see but the 2nd one is not as easy. You must be careful anytime your working with these components.
Posted on Jul 23, 2008
SOURCE: Taking Apart the Microsoft Wireless Keyboard 1000
There are two hidden screws under the two stickers on the back of the keyboard. Just feel around for slight indentations and stick your screwdriver bit down into it and unscrew. Keep in mind though, this may void your warranty.
Posted on Apr 21, 2011
How can I buy a new antenna for model sony cfm-165tw
Many boombox antennas are attached by a small screw through the pivot point. This is usually a #1 Phillips screw. Some do not have a swiveling antenna; for these you have to remove the back of the case to get at the attachment screw. Keep the screw; it's guaranteed to fit when you attach the new antenna.
The hard part is finding a replacement. If you have the pivoting/swiveling antenna, the Radio Shack 28" Replacement Telescoping Antenna 270-1405 ($5.99 online) will probably work. You might even be able to use it for a non-pivoting antenna that telescopes into the inside of the case.
Jul 22, 2014 | Sony Boombox Am Fm Tv Weather Band...
Cooling fan quite working on nv55c
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
May 24, 2012 | Gateway Computers & Internet
How to Replace the HP Pavilion dv7-4270us Fan
You will have to take the laptop apart to get to the fan.
May 10, 2012 | HP Computers & Internet
HOw Do I Take Apart a Dell Inspiron1764
LOL, just get some paper cups and label them with the screws you take off so that you will know how to put them back. It would take too long to go into details on how to tear a laptop down, but basically you remove the power cord, remove the battery, remove screws from the bottom case, remove the disk drive, remove the memory, remove the cd drive, remove the wifi card, remove the dvd drive, remove screws inside battery case, remove screws inside the hard drive case, remove screws inside the cd case, turn the laptop over, open the lid, remove the strip above the keyboard, remove screws holding the keyboard, remove the keyboard, remove screws holding the palmrest, remove the palmrest, remove the lcd hinges, remove the wires coming from the lcd going down thru the palmrest. Lift the motherboard out.
Apr 01, 2012 | Computers & Internet
How to open an LCD monitor.
I personally haven't worked on this monitor, but most monitors are held together with plastic clips on either side of the casing.
After removing the stand and all other screws, you will need to use a small flat-head screwdriver (or something of that nature) to pry apart the clips. Find the crease/gap in the plastic where the casing of the monitor comes together. Insert the screwdriver and gently twist and pry the casing apart. When you hear the first click/snap indicating the first clip has come apart, follow the gap with the screwdriver, prying it apart each time you reach an area of resistance. Do this all the way around the monitor.
Keep in mind that after you open up all the clips, the LCD panel and boards may be screwed either the front casing or most likely the back casing. So you must first unscrew the mounting screws inside the monitor to remove the back cover. Also be careful unhooking ribbon or speaker cables that attach the circuit boards of the monitor to the front casing.
Jan 12, 2010 | Gateway FPD2275W LCD Monitor
How to take apart hp ze5570us to see what is wrong with the plug socket for the charger? I have taken all screws out but the computer does not seem to be coming apart easily.
First of all remove all your components ie. RAM, hard drive, battery, CD/DVD drive etc. Sometimes there are screws located in the area where these components are located that secures the top and bottom halves of the case.
I suggest that as you remove the screws from the bottom of the case you take a note where the came from as some of the screws are different lengths.
There may be s strip panel between the top of the keyboard and the LCD screen, remove this first, it will be clipped in place and held with screws from the bottom of the laptop.
Next the keyboard should removed and keyboard cable.
Look closely for screws hidden behind plastic stick on covers, you need to use a sharp thin blade to lift off these covers to reveal the screws behind the covers.
The top and bottom halves of the case is usually held in place with plactic clips, start at an opening and carefully pull apart until a clip releases and the work along that edge to release more clips. Continue along each edge until you separate the case.
The LCD screen is usually secured with screws on the back edge of the laptop and possible with screws near the edge of the motherboard. Take care to disconnect the video connector.
The motherboard needs to be removed from the bottom half of the case so you can access the power connector.
Take careful note where you remove each screw as you need to put them back in reverse order.
Best of luck, have fun.
Jun 15, 2009 | HP Pavilion ze5570us Notebook
Broken arbor on lenox hole saw
Mine has a set screw some of them might threaded
Mar 15, 2009 | Lenox 48CT 3" Carbide Tipped Hole Saw
75 ohm antenna connection ''disappeared''
My antenna connector came off as well. After removing the two screw fron the back (on top), open the CD cover and remove the large screw at the front of the compartment. Now flip the unit over with the front of unit toward you. Insert a small flat screw driver between the cover and the botom on either side. There are two large tabs (either side) on the botom. pry away and up. Flip over and remove the cover. Careful of the ribbon cable inside, it is long enough to lift and flip the cover.
Nov 13, 2008 | Bose Wave Radio
Broken ringer
I discovered that I there was yet one more screw hiding under the little sticker near the antenna. Got that off, took the screw out, took the antenna off and the whole back came off fairly easily. The dead ringer (couldn't resist) was in the back casing. It's has a sticky backing so I pried that out, put the other one in and closed everything back up. Much to my delight, after having no sound from my phone for 18 months, I now have my ringer working again. And I saved myself $200!
Sep 06, 2008 | Palm Treo 650 Handheld
Cobra 38wxst was droped in water
The inner screws also need to be removed after you get the back panel off. Also, the antenna is connected with a nut to the case, and the antenna has a wire soldered to the board. They are kid of a trick to get into, but not impossible. Good Luck.
Ed
NC Electronic
Mills, Wyoming
Dec 06, 2007 | Cobra HH 38 WX 40-Channels Handheld CB...
Computers & Internet Logo
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
