Red motion lite keeps flashing just replaced old lite with defiant dfi-5988 two weeks ago worked good now red lite keeps flashing how to fix?
  • 23 Answers
I have the answer for the fan issue on the KDSR50XBR1!!!!!
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identicle. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank
What do you think? Spread the word, lets save some folks from spending needlessly...
Posted on Oct 07, 2008
The model number is KV-36FV15 and blinking is constant no pause
Posted on Nov 12, 2008
  • 225 Answers
SOURCE: Power on
The power board has parts going out on it. A slow decline in performance usually points to a bad capacitor or power transistor. Take a look at the power board. The board will show extreme overheating evidence if you had a meltdown. If it looks clean, maybe it is just a bad capacitor. If you see a capacitor that looks like the top is bulging out, that is a sign of a bad part. Unless you like to solder, consider this tv done for.
Posted on Nov 14, 2008
  • 4 Answers
SOURCE: Red lamp lite flashes along with power light.......
That is definitely the Light Engine (also referred to as an optical block) Very expensive.
Posted on Jan 08, 2009
SOURCE: No sound or picture, 2004 pt50dl54j
Cut n pasted from the service manual:
8.2. Power LED Flashing timing table
When an abnormality has occurred, the protection circuit operate and cuts the power supply. At this time, the defective line can be
identified by the number of flashes (red) of the power led indication at the front of the unit.
3 FAN SOS 94
4 MAIN 3.3V 88
Posted on Mar 14, 2010
Lost manual to program defiant daylight adjusting indoor digital timer
videos and text manuals.
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer ...
? 16:31
Jun 24, 2015 - Uploaded by Jasco Products Company
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer. Jasco Products Company. Loading ...
Defiant Daylight Adjusting Indoor Digital Timer with Motion Sensor ... Easily automate indoor or outdoor lights with the Defiant Daylight Adjusting Indoor Digital Timer. Program up to 7 on and off times per week. Auto adjusts to ...
DEFIANT 469-637 QUICK START MANUAL Pdf Download. - ManualsLib > Brands > Defiant Manuals > Timer View and Download Defiant 469-637 quick start manual online. DAYLIGHT ADJUSTING INDOOR DIGITAL TIMER. 469-637 Timer pdf manual download.
[PDF]Home Depot Defiant Timer - A-1 Electric Co., Inc. We appreciate the trust and confidence you have placed in Defiant through the purchase of this daylight adjusting indoor digital timer. Visit us online to see our. defiant daylight adjusting indoor digital timer Google Search
Mar 13, 2017 | Hardware & Accessories
I bought and installed the light below at home depot. It worked for a week. Now it still has power, bulbs work but the motion sensor doesn't activate the lights
Take it back, its faulty.
There is a sensitivity setting somewhere, try moving all the way up and then down a bit.
Dec 13, 2016 | Home Security
I have a 180 degree Defiant Outdoor Motion Security Light. It was working fine for 2 weeks, but now it stays on all the time. I've tried toggling it to Test and then back to 1 Minute and no change.
I am having the same problem. The manual says to avoid plugging into the same circuit as motors & fluorescent lights. Mine is on the same circuit as a freezer. I'm going to try changing the AC outlet to see if that helps. Good luck!
Sep 05, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Why did my motion light stop working and the sensor light is blinking red?
Did you find out why?? I just purchased 2 of these and loved them as they worked for like a week and now both are not working however they are getting power as the red light comes on when there is motion...Please help if you know as I paid 110.00 each for these and I am confused how the bulbs could be blown?
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
My motion security light keeps blowing only the left side bulb.
I assume you mean that the light bulb is failing. This can be caused by a faulty connection at the base of the lamp which causes the bulb to heat at the connection point. Remove the bulb and (with power off!) examine and clean the bulb socket.
Jan 19, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Dec 31, 2008 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
