Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell carpet cleaner won't spray water on floor setting
I have a Bissell Proheat 2X carpet cleaner that won't spray water on the carpet on floor setting. The brushes work and the vacuum works but it doesn't spray water through the jets when the trigger is pulled. The upholstery tool works fine - both water spray and vacuum.
  • dickkloppel Aug 02, 2009
    I ended up taking it to an excellent repair man - he knew instantly that it was a malfunctioning micro-switch in the handle that actuates the pump mechanism when the trigger is pulled.
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
Water will not spray
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rt2
Aug 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Steam cleaner will not **** up water
Try checking the lint filter. It is located in the top clear plastic section (the section with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch section) red plastic filter with a door on it. Flip open the door and you will probably find that it is clogged with hair, carpet fibre, etc.. Clean it out and you should have suction once again.
Apr 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner will not spray the cleaning solution
heatman101
hgjdg
Jul 21, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
4,759 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
