Question about Janome Sewing Machines
Janome 6600 the light for the up down needle position is on when the needle is in up position
3 Suggested Answers
SOURCE: Oiling a Jonome 6600
Remove the plate and bobbin case, beneath it will be a small round hole in the center. Inside the hole is a fluffy piece of absorbant material called the wick. DO NOT REMOVE IT! Place one drop of sewing machine oil on the wick. While you have the machine opened up, you should remove all the dust. I use the small brush that comes with the machine. Replace the bobbin case and make sure that it is clean too. Replace the plate. Lastly add a couple of drops of sewing machine oil to a q-tip and use it to apply oil to the needle bar above the needle clamp.
If your machine continues to squeek then bring it to a professional sewing machine repair technician and pay for the service to have it professionally cleaned and tune up. It is not worth damaging you machine over a few dollars well spent.
Posted on Jan 05, 2009
bargainbox
  • 1388 Answers
SOURCE: Janome 6600 displays E3 Error. How do I correct
Hi
Direct from the Janome workbook E3 error relates to:
"Stepping motor for tension release (MC6500P & MC6600P only)"
Ensure there is no lint or thread trapped between the discs of the top tension unit.........try "flossing" where thread goes down thru tension unit with a scrap of clean fabric.
It may also be the mechanism that releases tension when the presser foot is raised....it is a sensor and may be out of alignment...not really an easy home fix.
Let me know how you get on, just remind me of the issue as I respond to many.
Bargain Box
Posted on Jan 02, 2010
Janome 6600. Needle came loose &fell down into the bobbin area. Needle did not break off. I took off the plate and manually tried to move a new needle and shaft up/down. needle is hitting something
If you did not get the old needle out, it may be blocking something. That old needle must be removed before you attempt to any further sewing. Try removing the bobbin case from the machine and looking in there to see if you can locate and remove the old needle. Sometimes, I've had to turn the machine sideways or upside down and shake it to dislodge the needle.
Open the bobbin area and hand rotate the handwheel while watching the needle action. If it is hitting, you should see it. If that is the case, the machine may be out of time and need service.
Jul 11, 2017 | Janome Sewing Machines
I have a Janome sewing machine. There is a problem when i try to draw up the bottom thread from the bobbin. The needle doesnt go through the hole to catch the thread at the bottom
Please elaborate. Is the needle hitting the needle plate so it cannot reach the bobbin thread, or is the needle simply not moving down into the lower position?
May 21, 2017 | Janome Sewing Machines
Janome 6600 when auto cutter used it pulls the thread out of the needle
you might check to see if there is a burr anywhere on the auto cutter, you might need to have the auto cutter checked to see what might be wrong with it
Feb 28, 2016 | Janome Sewing Machines
How do I get my feed dog to move forward on Janome model6019
THE FEED DOG IS IN THE DOWN POSITION FOR DOING FREE ARM SEWING. SLIDE THE PARTS BOX OFF. THERE IS A SMALL SWITCH THAT YOU NEED TO SLIDE TO THE ON POSITION.
Dec 24, 2014 | Janome Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Feb 12, 2009 | Janome Memory Craft 9000 Computerized...
Oct 27, 2008 | Janome Memory Craft 5700
Sewing Machines Logo
35 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
