Question about Mamiya Cameras
How to replace sticky light seals on the back of vintage Mamiya m645j camera?
  • Mamiya Master
  • 5,412 Answers
You should be able to get replacement light seal kits on eBay for most cameras, but they may need a little judicious trimming for a perfect fit.
Posted on Aug 09, 2017
Testimonial: "Thank you!"
cammedic
  • 667 Answers
SOURCE: aperture diaphram on mamiya secor lens 80mm f/2.8
The lens has a lever marked A/M near the aperture ring. If the lever is in the 'A' position, the lens will stay wide open until you trip the control lever at the back of the lens next to the rear optics. In the 'M' setting, you can see the aperture move as you change the f-stop setting on the ring. Set the lens to anything but wide open and move the control lever with your finger. You should see that aperture move.
Posted on Jan 14, 2008
cammedic
  • 667 Answers
SOURCE: Mamiya 645 Super Replacement Parts
You can probably order direct from Mamiya, here is the contact info: Mamiya America
Posted on Mar 26, 2008
Gryfox
  • 216 Answers
SOURCE: I have a mamiya 645 pro camera I can't remove the
Squeeze the two handles on either side of the "120" or "220" label on the film holder to pull it out, then the spool is easily removed.
Posted on Jun 16, 2009
Obertelli
  • 3006 Answers
SOURCE: camera with a sticky substance on the back
It's a very common problem with older cameras and is an irreversible breakdown of the foam which was used to provide light-proof seals on the camera back and also to cover the pentaprism and provide a mirror buffer. (The pentaprism and mirror buffer are part of the viewfinder system).
The first problem is that when the foam turns to goo it allows light to leak into the camera and spoil the film, but that's the least of it. Where it gets serious is that the goo spreads inside and can gum up delicate moving parts; worst of all the goo is somewhat corrosive and can damage the coatings on the pentaprism leaving permanent residual ghosting images in the viewfinder.
The good news is that it's a well understood problem and every professional camera repairer can remove the goo and restore the camera as part of the regular service that all SLR's should periodically undergo. The foam will be replaced by modern materials which do not degrade. Some repairers also replace the mirror buffer, others will just remove the old foam and omit the buffer, but I always insist on a new buffer. At the same time, the repairer will give the camera a thorough CLA service (Clean, Lubricate, Adjust) which for a camera in non-professional use will often see it through a few more years, but I'd recommend getting a CLA done annually if you're well off and every couple of years if funds are tighter. The CLA will also ensure that the light metering is correct and on cameras using the older mercury oxide batteries can include a meter recalibration to allow use of modern silver oxide equivalents which have a higher voltage as the mercury cells are no longer available. (Some folks use manganese dioxide batteries, but they start off at a voltage slightly higher than the camera was designed for and constantly drift down with use to way below the nominal voltage, so metering is neither consistent nor accurate). A regular CLA with foam removal costs a bit more than a regular CLA but is a once only expenditure. Some repairers charge for recalibrating the meter for silver oxide batteries, but most won't if you politely explain that you can always take the camera elsewhere.
DIY kits are also available and some are very good indeed, but they can be fiddly and messy to fit and none of them address the more serious issue of the pentaprism. In practice, repairers will remove the old foam from the pentaprism but almost never fit a replacement. It's not strictly necessary and the reluctance to fit a replacement stems from the risk of further damage to the pentaprism by the adhesive. The outside of the pentaprism is normally painted black from new, but foam goo usually attacks the paint and partially removes it. it also attacks and removes any optical multicoatings on the prism. When this has occurred there is no fix: the problem will not worsen once the foam has been removed but there will be residual damage visible in the viewfinder as ghostly dull patches, but this is something which can be tolerated and will not affect image quality.
If you want a cheap quick fix, then use a q-tip (UK= cotton bud), a wooden cocktail stick/toothpick and some alcohol to remove all visible traces of gooey foam. Omit the mirror buffer altogether and take your chances with the prism foam. To replace the rear light seal just use a length of woollen yarn: you'll find that if you twist it slightly it will reduce in diameter and allow you to press it into the slot where the foam was using a toothpick. Usually you can get away without gluing it, but if any glue must be used then use a few very sparing dots of something easily removed such as Copydex or the rubber cement sold for repairing bicycle inner tubes. At the hinge end of the camera back will be a thicker, wider bit of foam. Just use a few dabs of glue or to secure a good thick double or even triple width of yarn. The fix isn't a professional one, but it's good enough and was how the seals were made before rubber foam was invented. It also buys you the time to decide whether you like using your Nikon enough to invest in a professional CLA with the additional options.
I hope that my reply has given you a few options and will enable you to get your camera into working condition again. All I ask is that you return the favour by taking a moment to rate my answer.
Posted on Jan 10, 2010
Tri3mast
  • 747 Answers
SOURCE: Mamiya 645 pro shutter doesn't fire
First thing that comes to mind on this camera is that it's a modular camera. This means the film back can be changed mid roll so there is what is called a Dark Slide between the film back and the body.
The dark slide needs to be removed before the camera will function. Also depending on how "new" the film back is there may be a dark slide holder/sleeve on the back side of the film back.
So you remove the dark slide and slide is into the holder so first you don't loose it and also it doesn't get bent.
Diagram
Posted on Jan 09, 2011
How to fix the lens, how to open it, need to fix the shooter speed, please someone i will try to explain better if someone knows something
The problem with this Sekor shutter units is that they become stuck by dirt, rust or grease and sometimes is impossible to fix it. In this model the lens unit can be seriouslly damaged if you try to charge it even it is so hard to move.
Oct 21, 2013 | Mamiya Vintage Auto-lux 35 Camera W/ Sekor...
Mac Won't Recognize Mamiya ZD Back
install the drivers for Mac operating system. Not windows;
Mar 16, 2008 | Mamiya RZ67 ProII Medium Format Camera
To repair the obturator the lens its a fixed lense how to open and fix it?
To open the mechanism you need firts to take out the front group lens (sometimes loosing 3 screws placed around the front ring).
After you take the front gropu out there is a nut that holds all the shutter unit attached to the camera. Turn it to the left to placed it out and then take the mechanism off. Be sure the are no other parts connected between shutter and camera before pull it out.
Oct 13, 2013 | Mamiya Vintage Auto-lux 35 Camera W/ Sekor...
I need help getting a polaroid back on my mamiya 645 afd camera
You probably nees the "P" adapter made to attach the back to the camera. If your item did nopt come with one, you will have to buy it seperately. Go to Mamiya.com and download the owners manual pdf.
Dec 18, 2011 | Mamiya Photography
Need a replacement back cover for my Mamiya 7ii. Where should I go in the UK?
please try here:
http://www.mamiya-usa.com/customer-service-service-repair.html
Aug 24, 2011 | Mamiya Cameras
I have a mamiya RZ Pro two and I am looking to find a digital back for it. If you could offer any guidance and advice I would be very greatful as there seems to be very little help for th RZ film...
Currently . You need a digital back adapter (approx.$1500.00+ US) then the digital back itself (Approx. 25,000+ US). yes that is correct!. THe RZ67 Pro II needs the DM56 adaptor then the DM 56 back itself. Why not check out the all new RZ22 (22mp) or the RZ33(33mp). The RZ22 is approximately $12,000.00 US and the RZ33 around $18,000.00. Hasselblad also make a 39 and a 50mp digital medium format, expect to pay 2-3 times that of a Mamiya. For a 35mm type dSLR, Nikon just introduce the D3X with 24.5 megapixals. The body alone runs anywhere from $6,500-$8000 US.
Sep 12, 2010 | Mamiya RZ67 ProII Medium Format Camera
Mamiya 645 ADF viewfinder/meter issues...
You likely have a defective display module, probably with a dead back-light. Try putting a newly charged battery in it, but if the problem persists, you'll need to send it in for service.
Aug 04, 2017 | Mamiya 645AF Medium Format Camera
I Have a mamiya 7, the screw cap for the camera battery has a plastic cap, it has broken and I can't replace the battery. I have had a look at a friends and his screw cap is all metal. I would like to...
i had a similar problem, and ordered one from Mamiya for about $19 including shipping. Now my problem is getting the metal part of the original cap off. any suggestions?
Feb 16, 2010 | Mamiya 7 II Medium Format Camera
Mamiya M645j film counter not advancing to start when roll loaded
It's a common problem in the 645 - if you want to do it yourself, without a permanent fix, put a DROP ( not a lot ) of lighter fluid, or rubbing alcohol on the tip of a fine screwdriver and apply it to the gear you use to rewind the camera, and turn back and forth a few times. If that doesn't loosen it, it'll have to be disassembled.
Jan 07, 2009 | Mamiya 645 Medium Format Camera
Mar 26, 2008 | Cameras
Cameras Logo
66 people viewed this question
Top Mamiya Cameras Experts
Tony Parsons
Tony Parsons
Allen Showalter
Allen Showalter
Level 1 Expert
Are you a Mamiya Camera Expert? Answer questions, earn points and help others
