Question about Vizio Televison & Video
My 3 year old climbed on the counter and got ahold of a bottle of disinfectant and proceeded to clean my 65in. Vizio tv with it. It dripped down in the front and now it has no picture, just vertical lines shooting up it. I unplugged it hoping it will dry out. What part could it have damaged? Or if I replace the t-con board, power supply board, main board or the Led driver will any of these fix the issue?
  • Vizio Master
  • 5,309 Answers
It rather depends on where the liquid went. However I don't think it will have done the LED screen itself any good at all. And if that is the case the TV is probably a right off. A visual inspection of the boards might help, but you might finish up replacing all the boards! In such case a new TV might work out cheaper. Are you covered for accidental damage at all?
Posted on Aug 09, 2017
  • 1 more comment
  • Jessie Stewart Aug 09, 2017
    No coverage that I know of. I think I had a 2 year warranty but I doubt it covers that. However, I found a complete kit with every board in it for a pretty decent price. So if i were to replace all the boards, would it fix the problem or is there more to the screen operating than that?
  •  Grubhead
    Grubhead Aug 09, 2017
    Replacing the boards, providing there is no screen damage might solve the problem. Make certain you wipe dry and clean any of the wire connections before fitting the boards in place. You don't want any trace of the bleach around. Be careful not to touch the boards with your hands, due to static discharges from you to the parts. Use either insulated gloves or an earthing strap, which you can buy cheaply.
    The warranty would not cover it and is of course void once you go inside the unit. I was thinking of household insurance.
    There is no visible damage to the outside of the screen that I can see. I haven't taken it apart yet and I'm not a repair lady so I'm not exactly certain what all the screen consists of. It powers up and has back lights just no picture, only vertical lines that flash around and then it goes blank. I don't really know how it all operates. I've fixed my old dlp projection tv so I guess I'll learn something new when I operate on this one.
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
SOURCE: LTV-32w1: Vertical scrolling on screen. Already
Rolling or sync bars can be caused by bad caps in the tuner. I also had a brown film all over my board. Clean with alcohol and repace the 2.2/50 caps in the tuner. l
Posted on Mar 07, 2011
welcomejee
  • 10594 Answers
SOURCE: Vizio 47" LED TV, I have a vertical red dotted
I think I gave you info about tv problem in chat session that was rated Not Helpful, let me know if there is further question.
Posted on Jun 04, 2011
  • 742 Answers
SOURCE: I have a samsung lnt4066 led TV with a distorted picture. I have replaced the main board, power supply and the t con board with no success. I have pictures of what the TV is doing and would like to sh
You either have a bad t-con board or the screen is bad. Check to make sure all the ribbon cables are seated fully and connected. Even replacement parts can be bad sometimes, new and used both.
Posted on Jan 09, 2015
gopakumarg43
  • 74822 Answers
SOURCE: Vizio tv model:E502AR
In fact; you have to replace the display panel too to make the TV a new one. Contact any service technician. It will be best.
Posted on Jun 16, 2015
X5 H2O Steam Mop dripping water from small hole at bottom and not producing much steam
john, I would try cleaning the mechanism with vinegar or CLR to dissolve any buildups you can't see. Rinse, fill up with fresh water and powerup. good luck
Mar 13, 2014 | As Seen On TV H2o Mop X5 5-In-1 Steam...
Need help please. Why has my Vizio TV malfunctioned? And what are my options?
It sounds that the T'Con board [Timing Control Board] to your TV is faulty. But before confirming it, just re-seat all the flat cable connections from it to LCD panel. You must have knowledge in electronics to proceed. Otherwise, seek help of any experienced service technician.
Jul 10, 2012 | Vizio M260VA 26 in. HD-Ready LCD TV
Can I use Polish Stones are substrate for my lizards?
No, because they require large amounts of waterto thoroughly wash, disinfect, and rinse the disinfectant from them on aregular basis, but you can use them to add some interest to your habitat. Theyshould also not be used as climbing walls for lizards as they are too smooth toclimb.
May 14, 2012 | Reptile
My tv stopped working with my DVD player
Call Vizio for a warrenty repair.Ur DVD Combo,the laser eye is dirty,must take the tv aparts and clean it.But it under warrenty,take ur warrenty from Vizio let them take it aparts,can clean it for u.
Apr 06, 2010 | Vizio VA19LHDTV10T 19 in. LCD TV
Black line on hitachi projection tv
sounds like the water has went under the rim and dried there the line will never disapear
Jul 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Rascal scooter mo 655 motor stops going up hills
the batteries could be the problem, is it possible to try some other batteries, silly question , how steep is this hill ? remember scooters cannot climb steep hills as the motor will shut down due to the increased load.
1 Year old batteries ok ? but if they get used on a non daily basis and are not fully charged after use, I would question the batteries but again the motor could be overloading,
How much do you weight ? sorry for the personal question but it all loads the motor and that increases the current and that will cause the motor controller to shut it down.
Jun 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
How to Clean my Toilet?
Growing up the son of a plumber, I would have provided the same answer as Tina. However, Since November, 2014, I'm out with the old way and have been conformed to being more environmentally friendly and with proven results.
clean-toilet-2a0cfbtak4y3luwyen1qnfe3-4-0.jpg I purchase these quality products here:
www.ChristineFrey.Norwex.biz
Thank you for making my cleaning life easier, faster and effective! I now have more time for my children!!!!
Aug 27, 2008 | Kohler - Toilet Tissue Holder - Bancroft...
Danby counter top dishwasher
CLR should do the trick, read instructions on back of the bottle. Also there are some dishwasher cleaners that you buy.
I bought one at Safeway. Small bottle, has a picture of a dishwasher on it. It has a wax seal that melts when you run it on the hottest cycle upside down. It cleans the inside of the dishwasher.
Of course this is assuming that its build up.
May 31, 2008 | Danby DDW496W Free-Standing Dishwasher
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
