Question about HP Garden
I'm trying to find a recoil starter part for a Ranch Kind 14.5 HP 42", Model #287757, Type: 1224E1, Code: 9982827F. Can you help me find one?
  • 3 Answers
Your problem could be caused because your valves are not set properly (they vibrate loose sometimes. Remove your spark plug and try to crank theengine...If it turns freely with the pulug out, reset your sure to obtain the proper spacing (gap). Hope this helps
Posted on May 06, 2009
  • 153 Answers
SOURCE: ranch kind 16.5 horsepower riding lawnmower
A dead battery would be top of the list by far, followed by solenoid, keyswitch, wiring, starter in that order.
Posted on May 29, 2009
  • 2220 Answers
SOURCE: broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Posted on Sep 05, 2009
  • 70 Answers
SOURCE: How to change the pull starter cord.
drill out rivets then re-rivet or use self tapping screws
Posted on Oct 04, 2009
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
Recoil starter will not pull out but can be done in careful stages
If the recoil is working fine until it is mounted on the engine then there is most likely a problem with the engine, not the recoil. More info would be helpful too.
Jun 18, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
Recoil starter rope only pulls about 1/3 of the way back in.
The recoil starter is damaged or tangled up inside. Some can be disassembled in made to work but if not a new recoil starter can be purchased. I hope this helps.
Aug 15, 2011 | Agri-Fab Agri - Fab Snow Blower - 42"
Spring on recoil starter broke after using generator third time. now mcculloch says recoil starter is not available.have to purchase entire starter housing assembly for $105.00
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
Sep 13, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
I have a Ranch King Push Mower. I can't figure out how to get to the coil rope to fix it. I took the top off, but I still coulnd't get to the coil rope. Can you help please? Thank you!
The starter/recoil unit should be bolted above the flywheel. Can you just remove the bolts holding it in place and lift it off....or are there rivets there that won't allow it's removal?
Aug 24, 2010 | Garden
Try giving a few light tuggs and hopefully the spring will recoil itself. If not, you probably spung the spring and you will need to take apart the recoil assembly to get it working again. BE CAREFUL, springs have a tendancy to just 'jump' out and completely uncoil themselves and then you will have a headache for sure. Also, try reaching under the deck (hopefully the motor isn't running :P ) and turn it counter clockwise while someome one tugs at the rope. Many times it will engage itself and rewind just fine. Let me know what happens
Sep 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 and...
How do you remove the recoil starter cover. I
which kind of chainsaw, make, model, how old?
Jul 09, 2009 | Garden
Ranch kind 16.5 horsepower riding lawnmower
May 29, 2009 | Garden
MURRAY AUTOMATIC DRIVE, 42" CUT, 17HP, TWINII,MODEL 42A707,TYPE 2653E1,CODE 9710235B. Battery fully charged,starter will not turn fast enough to start engine. acts as tho there is a presure build up....
Dropped / Stuck valve?
Major Overheat?
Battery weak (understand it is fully charged... but is it delivering proper amperage under load?)
bad connections betwixt battery and solenoid, then solenoid to starter?
Weak starter motor?
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
23 people viewed this question
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
