Question about La Cimbali Coffee Makers & Espresso Machines
Cimbali m29 selectron 2gr espresso machine. power outage from electrical source. when power was restored, tank heats up and comes to pressure, however no water will dispense from heads...
...when dosing buttons are pressed. water will dispense intermittently from one head when sitting idle. fried board? or is there something simpler?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • La Cimbali Expert
  • 373 Answers
* You will need to program groups again.
* I'm surprised I did not record and upload a programing video *sigh*
Oh well, somebody did it already:(check at 3:57 on the following vid)
https://www.youtube.com/watch?v=0-3SbS-PU4Y
* Set up each shot with a filled portafilter (for the appropriate dose setting. Single for single, double for double, etc.)
* Press and hold "Stop" button till it light (and/or beeps). Release stop button
* press and HOLD the appropriate dose button (within 5 seconds or it cancels out)
* Watch the coffee dose as it pours out into cup or a shot glass (for accuracy)
* Release the dose button just before it hits the desired amount. You may have to do this several times to practice.
* Continue with setting the dose on the other settings (long, double, etc.)
* Note; you can set the "least used group" as in a 3 or 4 group head machine with specialty doses. Like a triple if you have the proper portafilter for this shot. Or an "American" long shot (though I don't recommend running 6-8 oz of water through a single coffee dose. Though I have found some shops using drip coffee through a triple basket and very long dose to fill mugs. They didn't want to get a regular 12 cup brewer.)
* There are other dosing tricks like copy over to other groups. But I've found that setting each group and dose is good practice. (and I have to do it several times a day as a Espresso Tech.)
Aloha, ukeboy57
Posted on Jun 05, 2018
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: i have a cimbali m29 selectron i have no power
Sounds like the problem is in the keypad.
Posted on Oct 07, 2009
guido817
  • 6 Answers
SOURCE: La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
Posted on Mar 27, 2012
My Cimbali m29 start runs continually the steam shoots out the top all the time and sounds like it is going to blow up
The pressure switch is stuck in the closed (heater on) position. It's either clogged at the pipe to the switch or the orifice of the switch is crusted up. check out ukeboy57 on youtube for a detailed repair of the pressure switch and how it works. It's also possible the heater is busted open in the tank. The tank heats up very slowly after making a lot of drinks. Then blows safety valve once it over heats. This is a deeper problem and it would be best to start looking for another machine. I have additional vids on tank cleaning but it's better just to get another machine if it's older than 5 years. ukeboy2@yahoo.com
Aug 23, 2013 | Espresso RMI La Cimbali Espresso Machine
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
How do you calibrate the dosing of the La Cimbali M29 Select?
should be the same method unless the stop button needs replacement. The stop button is one of the most often used (abused) buttons and frequently needs replacement.
ukeboy57
Mar 26, 2010 | Espresso RMI La Cimbali Espresso Machine
WANT TO BUY A SECOND HAND M29 SELECTRON 2 GROUP- LA CIMBALI
The price for the m29 select new is about 5500 to 6000. So for one of 4-5 years you can give about 2500-3000. However I sugest to open the machine and check if their are rusting points or any leaking points which propably be white points from calcium color. Also ask if their were any water filter like everpure or and a water softener conected to water supply of machine during the operation of the machines.
If you see minor points as above and the water was treated before entering the machine then your machine can work for minimum another 10 years.
Water calcium (scale) is the biger enemy of the machine.
Good Luck
Mar 10, 2010 | Espresso RMI La Cimbali Espresso Machine
Can you turn off one of the left or right sides on a La Cimbali m29 Espresso machine?
1-Cover the buttons on offending side (paper and 1 min to do)
2-Reprogram one side to give it a short dose. (5 mins to do)
3-remove power to group valve (screwdriver and 20 mins to do)
Note if you do remove the power, please leave a note for the crew as they will probably call a technician in to 'repair' it again.
Aug 19, 2009 | Espresso RMI La Cimbali Espresso Machine
La cimbali m28 selectron manual could anyone tell me where to buy or down load one
This is for you....I hope this M29 will do what you need...I called he Cimbali 1-800 number and this is all they had...I tried...been working on this one for about an hour...found one in Russian....Italian...Spanish....but when I translated them and tried to paste them they came in both languages and intermingled somehow....wierd....but here you go ....I hope this helps...good luck and thanks for rating my effort....The Fang
P.S. any probs...call 1-800-724-6225 and speak to Trish. Thats 1-800-Cimbali. Take Care
May 19, 2009 | Espresso RMI La Cimbali Espresso Machine
Cimbali M29 Select
Remove the 3 screws on the side of the bell they might be bolts or allen wrench screws. That will give you easier access to the screen and screw(make sure you have extra screen and screws).
Aug 18, 2008 | Espresso RMI La Cimbali Espresso Machine
La Cimbali M29 Select - No power
sometimes italians use brown colour for neutral, please check it. if it is so than the problem is solved
Mar 19, 2008 | Espresso RMI La Cimbali Espresso Machine
Coffee Makers & Espresso Machines Logo
51 people viewed this question
Top La Cimbali Coffee Makers & Espresso Machines Experts
ka4iup
ka4iup
AAAA262430
Mark Cheong
Mark Cheong
Are you a La Cimbali Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
