Question about Elna Sewing Machines
My elna machine has jammed and cannot move it at all. When turning the wheel the needle area does nothing.l tried oiling It but nothing. Please help as I have to finish my sewing. Thanks
It is an Elnita ZZ electronic
SOURCE: Thread jams in bobbin area
well i have done the same thing , all u need to do is if you see the screws that hold the bobbin area you un screwq thoes and get you a pair of scisors and cut around the knoted mess and all you do is work with it until it is all out and you dont realy want to pull on it to much you know just work it around so it gets lose so that you can cut it out thin you put it back together and try it out.
Posted on Nov 25, 2008
  • 9 Answers
SOURCE: Sewing Machine
Your belt may be broken
Posted on Jun 26, 2009
  • 8 Answers
SOURCE: necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
Posted on Jul 18, 2009
  • 980 Answers
SOURCE: l have an elna sewing but no model number, it says
That is the exact model, there is no number.
Posted on May 29, 2010
SOURCE: necchi sewing machine problem
needs to be serviced
Posted on Jul 31, 2010
Elna sewing machine is jammed or frozen needle does not go up or down
Sharon, I am not a sewing machine expert, but will post some links that may help you get your machine up and running. You can also google search your problem for a lot for info. on this issue. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Needle is Stuck My Hand Wheel Won Move HELP It Just Sewing
HOW TO FIX YOUR SEWING MACHINE IN 5 EASY STEPS
Help me diagnose and fix problem with my sewing machine
Jul 29, 2016 | Elna Sewing Machines
Elna 2130 runs slow and won't go to full speed?
1. Make sure the bobbin assembly is clear of all left over rags, threads, etc.
2. When you return the hook (sharp thing) it needs one drop of oil on the track. (track is what the hook rides on)
3. Take off the top and bottom lids. (Not too difficult)
4. While turning the hand wheel you will see parts moving. At areas that you see metal against metal movement. Place sewing machine oil on these areas. You may want to start by cleaning with a qtip first.
5. Make sure the needle arm (going up and down that is attached to the needle) gets oil. Also, put a small amount of oil on the pressure foot arm. (has a spring around it)
6. If it isn't still working as fast as you would like do the following.
7 Remove the plate that surrounds the hand wheel.
8. The rubber part that goes between the motor and the hand wheel may need to be replaced. (Not usually the problem) Just give a glance and see if it is in bad shape. If so then replace.
9. The motor and the hand wheel need to be aligned. Loosen the bolt that attaches the motor.
10. (Remove needle) Give the foot pedal some pressure and move the motor to a point where you hear the motor move the fastest and with very little resistance. This is where you will tighten the motor.
11. Put your machine back together.
Jul 10, 2015 | Elna Sewing Machines
How to get the needle to come up nothing will move on a 130 elna contessa
my sewing machine would do that from time to time, try turning the wheel hard enough to break the thread if it's stuck, if that doesnt work then try unscrewing the needle and turning the knob so that it lifts away from the needle then you can get a better view of whats going inside.
Jan 10, 2015 | Elna Sewing Machines
Elna SU needle position lever is very stiff
this is probably due to lack of use and just stiffening up of this lever, best thing is to take off the top cover and get some triflow oil into the lever area, then try to work it back and forwards. First though, always set the stitch length and stitch width dials to zero before you try to move the needle dial, this applies to changing the stitch selector too, always turn width and length to zero first to avoid wear on these parts internally.
If you are happy to delve a bit deeper into your machine internally you might want to join the Yahoo group called Elna Heirlooms where other Swiss elna owners share their love and knowledge of these machines, there will be message thread on this issue there for sure.
May 08, 2014 | Elna Sewing Machines
Elna SU purchased in 1977 jammed; rotating wheel is unable to move forward
it sounds like the machine needs to be serviced at a sewing machine
shop
May 05, 2012 | Elna Sewing Machines
Elna 6200 jammed on bobbin refill setting
Remove thread. Remove the needle plate. Turn hand wheel toward you. Rethread machine. Make sure presser foot in up position when you thread needle. Make sure needle all way up in shaft, flat side back and more rounded side facing you Turn hand wheel toward you again and observe the following: As needle comes down, make sure the needle's eye makes pass by the scarf of the needle. Hope this helps, and if not, try sewvacdoctor.com
Apr 03, 2012 | Sewing Machines
Elna 9000 bobbin problem
try changing the needle,,make sure the needle & thread & fabric are correct for each other
make sure the bobbin is turned the right way
it's also possible that when the needle gets jammed or broken that the machine can become out of time
and would have to be retimed at a sewing machine shop
Apr 01, 2012 | Elna Sewing Machines
Needle centering wheel is stuck tight and cannot
On these machines, the shaft UNDER the centering wheel fits into a bushing, and this is what normally rotates. The wheel is fixed to the shaft. Penetrating oil needs to be placed UNDER the centering wheel but above the bushing. We solved this problem on two machines by saturating dental floss (the kind used to clean braces) with penetrating oil. Insert the floss UNDER the plastic wheel around the shaft, with the two ends sticking out the slot for the centering wheel. Then cycle the floss in and out of the area around the shaft. Let it soak and repeat. It takes some time, but it worked, and did not require disassembly of the machine. Greased Lightning also was used. Kithen grippers help with rotating the wheel.
May 07, 2009 | Sewing Machines
Sewing Machines Logo
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
