Question about Vizio Televison & Video
Vizio model E500I-Bi when I try to turn the tv on it won't go no. Sometimes I get sound. If I unplug it and push the on button for 10 seconds then plug it back in and turn it on it will work.
When I turn it on the on light will go no and fade with no logo coming on the screen. What do I do to fix it? It is only a couple of years old.
MNfisherman
  • 11896 Answers
SOURCE: Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Posted on Aug 24, 2009
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Posted on Nov 22, 2009
SOURCE: Insignia LCD TV 32 inch will not come on
I received no replies to my request. I guest I stumped 2 million techs. I'll just buy a new TV with a 5 yr warranty. No thanks to joining your service, I can do bad all by myself.
Posted on Feb 09, 2010
toolkits
  • 1099 Answers
SOURCE: Volume fades out then may come back on-Proscan TV Model#PS35690LW
hello,
this will require you opening the back cover of the television.
Check for dry soldering and re solder in the audio section of the printed circuit board....
Good luck...
Posted on May 24, 2010
eagle338
  • 4889 Answers
SOURCE: my vizio flat screen tv
You have faulty electrolytic caps in the power supply section of the tv. Capacitors with reduced quantities of electrolyte take longer to charge compared to normal ones. That is the reason its coming on after you repeat the on/off sequence a few times. If you are not good at soldering, replacing the power supply should do the job. It should cost you about 75-100$. Let me know if you want to do it yourself(please get me the model number of the set as well so that I can find you a replacement).
Sai.
Posted on Dec 28, 2010
Vizio 60" smart tv screen bottom section of the screen is lighter than the top
Sounds like you have some bad lamps in the panel that need changing, in time the backlights will totally go out and the set will have a black screen
Mar 16, 2018 | Vizio Televison & Video
How difficult is it to replace a blown speaker on a E500 Vizio TV?
Easy if you can get inside the case.
Audio Speakers 2 Subwoofer No Effects SRS StudioSound, SRS TruSurround HD, SRS TruVolume Total output power 20 watts
Read more: http://www.digitaltrends.com/tv-reviews/vizio-e500i-a1-review/#ixzz3vkDj3Zwp
Follow us: @digitaltrends on Twitter ' digitaltrendsftw on Facebook
Or you could buy a surround sound speaker bar which disables the internal speakers.
Dec 29, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
No sound from E371VA Vizio TV
tried first with unplugging and re plugging the tv unit to reset the power supply as will as the any program.
Nov 14, 2012 | Vizio E371va 37-inch Full Hd 1080p 120 Hz...
No Screen or sound
there are two possibilities to this problem. First and cheapest way is to replace the main board. Second, replace the inverter board. This is the boards that are mounted vertically on both sides of the TV.
Jun 18, 2009 | Vizio VU42L 42 in. LCD TV
Televison & Video Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
