Question about John Deere Garden
Were can I get a drive deck pulley for a John Deere rx63
    Top Expert:
  • John Deere Master
  • 12,744 Answers
Online search or john deere
Posted on Aug 09, 2017
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
  • 5 Answers
SOURCE: need john deere stx38 mower deck belt diagram
Go to http://outdoorpowerinfo.com/repairs/deere_stx38_gear_drive_belt.asp
for pictures and descriptions of drive belt and deck belt on John Deere STX38 and STX46 tractor with black deck
Posted on Oct 22, 2009
SOURCE: How to install John deere lx255 42c mowing deck
How to install John deere lx255 42c mowing deck blade belt
Posted on May 20, 2010
The belt keep jumping off the tension pulley
If the model of deck you have has a belt coming from the engine to a double pulley on the back of the deck you might want to check to see if the bearings are bad on the double pulley. If I had the model of the mower it would help, they make different types of 47" decks.
Jun 02, 2017 | John Deere Garden
I have a John Deere 820 tractor. I ran over a brick with mower blade engaged now I can't get blades to re-engage.
You probably have sheared the safety pin in your pulley drive. To change you have to take the pulley off. Try turning the pulley by hand If it turns free you did shear the pin.. Take spark plug wire off before so you do not hurt yourself. Safety first.
Apr 25, 2016 | John Deere Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
I need a diagram to replace belt on a 60 in deck on a John Deere 420
Make a loop with the three drive blade pulleys, the other two are tensioner pulleys, if they are flat pulleys as they should be the back side of the belt rides on these , if they have been changed then use them as tension pulleys anyway you can, hope this helps.
Sep 14, 2014 | John Deere Garden
Why isn't the center blade on a john deere LX178
Of course with everything off, reach under the deck and turn the center blade by hand. If:
1. the blade turns by itself and nothing else moves, you need to tighten the retaining bolt more.
2. the blade, retaining bolt and drive shaft turn, check to see if the pulley above it is turning.
a. If the pulley turns freely check that the drive belt is going around it to power the blade.
b. If the blade turns with the drive shaft and the pulley doesn't, check that the pulley is still properly connected to the blade shaft. Some have a key in them that can split, others just have a bolt on top holding them tightly on the shaft.
Jun 16, 2011 | John Deere Garden
John Deere tractor
Ok Simple Rule
V BELTS go in V pulleys
Flat pulleys get the back of the belt. You must take the deck off the tractor to do this properly. Look inside the hood I have seen belt diagrams there or on top of the deck.
When all else fails Go to the JD Dealer they will gladly help.
Sep 29, 2009 | Garden
Garden Logo
48 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
