Problem ir2318 front\Left cover open close cover
3 Suggested Answers
mishrajk21
  • 202 Answers
SOURCE: paper jammed at this time error message show on
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
Posted on Jul 14, 2010
emissionwiz
  • 79865 Answers
SOURCE: what is the cause of this problemfront/left cover open close cover
What message shows?
Posted on Aug 11, 2016
How do i fix this "front/left cover open close cover"
Since you don't mention it I will assume that the cover appears to be properly shut. The sensor for this is likely a blade type or possibly a magnet type depending on the printer. Open the front cover and see if the plastic blade is present and enters the proper slot. If so then it is likely that the sensor inside is loose or has shifted so that the sensor no longer 'makes' when the covere is closed. If you are familiar with the disassembly of your printer you may wish to investigate and see if you can resolve. If not or if the unit is under service or warranty please contact the appropriate person.
Aug 11, 2016 | Office Equipment & Supplies
Ir2318 canon copier front\left cover open close cover
make sure that all covers are closed if ok may be one of sensors is defective & need to change.
Sep 06, 2013 | Dell 1700 Laser Printer
How to check counter in IR2318
just open the front cover then you will see got two counter inside
Nov 26, 2010 | Canon imageRUNNER 2200
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
Dear Sir(s) I have an OKI data OL400e the problem is "Message --Cover open" even i close it well Please advice Thanks
had the same problem. It is easily fixed.
On my printer a OKI C5750 is had to main covers, at the front (which you have to open to fix a paper jam) and a big cover on top (which you need to open to replace toners).
On the left is a piece of plastic which (when closed) presses on a switch.
When you open both covers, and close the top one, you can see it on the left when it comes down.
You can easily remove the error (only for a brief moment) by prushing the shining metal switch to the back.
But the problem is that one of the rollers is in a wrong position.
So just take a flat screwdriver and press on the bottom roller, and it will click and the problem will be gone when you close the covers.
Feb 11, 2010 | OKI OL 400e Led Printer
How to replace savin c3030 waste toner bottle
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Dec 05, 2009 | Office Equipment & Supplies
Close cover 310: cover open, but it isn't
Nov 23, 2009 | OKI C3400n Laser Printer
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
Copystar CS-1500 "OP" flashing in display
Hello, 'OP' means that the front or upper front cover is open --- close the cover securely. If the message is 'OP1" then the left cover of the document processor is open, close that securely.
Jan 05, 2009 | Copystar CS-1500 Copier
k24674
jasbo
jasbo
