Question about Kohler Electrical Supplies
I have a kohler CH730, HAVE HEARD horror stories about this engine. Several years ago replaced head gaskets! Now it blows heavy smoke not again. WHATS UP!!
stormbrewin
  • 426 Answers
SOURCE: f-150 4.9 lt .once it starts, blowing heavy black smoke
Sounds like its flooding(excess fuel)Try squeezing the main fuel line enough to allow enough fuel through for engine to run smoothly if that improves running of engine either fuel pump needs replacement or pressure relief valve has failed or has no vacuum to activate it.Dirty or failing injectors can also cause your problem,try putting a can/bottle of injector cleaner in fuel tank to see if it improves running of engine.Air flow meter can also be an issue.A few potential reasons foryour problem and too hard to lock it down to a single cause without the vehicle being in front of me to do the appropriate tests so have just provided the basic causes and hope your able to take it from here and solve the problem.Good luck
Posted on Dec 26, 2008
  • 176 Answers
SOURCE: coolant leak/head gasket
If you have a head gasket leaking, and your engine is blowing a white smoke from the exhaust pipe, then you're taking coolant/water into your piston/s.
After a heavy acceleration your pressure is forcing more coolant/water into your cylinders..but don't be fooled..water/coolant is also getting into your cylinder/s when you're driving slow too.
You should get the head gasket repaired as soon as you can, or the head gasket may very well let loose and then you get to deal with having the heads shaved if they warp from the heat.
Either way..you really should get the gasket replaced soon.
Posted on Dec 31, 2008
lester482529
  • 226 Answers
SOURCE: briggs and stratton engine smoking
if your oil level is to high it will do this. i would drain and refill the oil to oem specs slowly as not to overfill so it doesn't blow over the top of the piston.hope this helps
Posted on Jun 25, 2009
  • 5603 Answers
SOURCE: I have a KRK Rokit Powered 5 studio monitor and
Look for a failure in the power supply section. You will need electronic experience or someone who has that.
If the fuse is glass and blows silvery inside thia means a direct short inside. SUSPECT the input rectifier or filter capacitor(s).
Do testing with a 100 watt light bulb in series with the hot side of the power cord to avoid blowing fuses.
Posted on Oct 11, 2009
SOURCE: kohler CV15S on a John Deere LT155 smokes alot. I
I also have a John Deere LT155 Garden Tractor, and 'I have issues with white smoke and cannot get it started. I have detected gas smell in the oil. Quick call to a JD service centre told me it was likely a head casket. If the smoke is white, then that is likely your problem.
Posted on Sep 23, 2010
Mower blows heavy blue/white smoke at random.engine stutters stops after idling a bit then does it again rounds later
which engine ???
Kohler ???
Briggs ???
oil over full, water in gas tank, bad gas in gas tank,
can you say head gasket ???
Apr 27, 2015 | Garden
My mower is blowing white smoke from around the front of the engine, what is the problem?
Sounds like coolant burning in the cylinder.. hopefuly it's the head gasket and not a cracked head. note* NEVER wash your mower with cold water when it's hot !! The only special tools you will need are a torque wrench and a wheel puller for the flywheel, magneto ( cord reel).
Aug 11, 2014 | Cars & Trucks
KOHLER SMOKES STARTS UP ONLY HOT OR COLD,NO SMOKE WHEN RUNING
look down inside air cleaner before starting next time , if theres more than a finger full of motor oil in there then your head gaskets are going
May 20, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
How do you know if you have a blown head gasket?
you my have thick smoke coming out of your tail pipe or oil leaking out on to your engine
Sep 12, 2012 | 2005 Kia Sedona
Kohler ch20s - The engine back fires through the carberator and seems to pessurize the crankcase - it blows the dipstick out as soon as it starts- well sorta starts. What could be wrong? There is very...
Yes it could be timing except for the fact that the dipstick is blowing out. I would look at one of two things. 1. the head gasket is blown internally allowing for compression to bypass into the oil sump. or 2. the rings are worn out or on wrong allowing the compression to leak into the oil sump
If you take it to a good dealer like www.arcolawn.com they can perform a leakdown test and tell you very quickly what the problem is.
It might be worth purchasing a couple head gaskets and check. good luck
Joe
Feb 15, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
We are replacing head gaskets on kohler command 25 68500,what are the torque specs for head and intake gaskets?
first torque to 16ft/lbs in a x patt. then 30ft/lbs in a x patt. for head the intake gaskets connecting to the head should be 12 to 17
Feb 02, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
CH670-0011 22hp in cub cadet 115 Hours smoking replaced head gasket but observed that ring job was needed Is this a normal problem with the Kohler V twins?
no it is not common long period's of sitting the lube will wash off the rings and a squirt of oil will help prolong life of the rings that's if the engine was sitting for a wile hope this helps
Aug 23, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH20S losing power, blowing black smoke and oil
Sounds like engine is flodding. Have carb float checked, make sure it is at the correct height
Feb 04, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I have a 1998 chevy 2500 4x4 6.5 diesel pu.truck starts and seems to run normal ,maybe a little loud, i heard chevy diesels this year are louder than fords etc. blows a little white smoke at startup some...
the head gaskets are blown you can believe that anytime on any engine gas or deisel that you get oil in the radiator and there water/ antifreeze in the oil pan the gaskets and or cylinder heads are bad
Jan 20, 2010 | Chevrolet 2500 Cars & Trucks
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Electrical Supplies Logo
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
