Question about Sewing Machines
Can I adjust the needle threader?
It doesn't line up with the needle eye.
  • Sewing Machines Master
  • 9,530 Answers
I have made slight adjustments to my manual threader. Sometimes it gets bumped and turns so it does not meet the needle eye. Be careful because they are rather delicate.
Posted on Aug 09, 2017
bargainbox
  • 1388 Answers
SOURCE: Needle Threader is not lined up
This is called the Needle Threader Plate.
If this is too small for you to read, or you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
RickE1
  • 202 Answers
SOURCE: Broke the hook off the automatic needle threader
You can get a new (grey) threader inexpensively that pushes on the bottom of the threader shaft from a dealership. Easy to do it yourself or they can do it in 5 or 10 minutes. Try taking the old one off and looking at it. It pulls right off.
Posted on Dec 01, 2008
  • 323 Answers
SOURCE: Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
Posted on Apr 11, 2009
RichSew
  • 184 Answers
SOURCE: janome 1860 needle threader
If the hook is bent, you might be able to straighten it, but I would go to my dealer and purchase a new threader. It is much easier to replace it.
Posted on Feb 09, 2012
  • 539 Answers
SOURCE: automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Posted on Apr 01, 2012
Testimonial: "I didn't know that the threader hook can be replaced. I just had the machine serviced... the auto threader worked for a day or so, and then not. It seems that it is permanently out of alignment. I took a class once from a teacher (a long time ago, not related to the current situation), and when the threader stopped working, she got out her little tool and fixed it on the spot. I'd like to know how to do that."
Automatic needle threader
Usually, the needle needs to be raised so the needle eye will match the threader. However, perhaps your threader has been bent or inadvertently pushed up or out of position.
Jun 06, 2017 | Sewing Machines
HOW TO ADJUST my needle threader on my Pfaff Creative Visions 5.5 sewing machine
If the tiny hook on the needle threader misses the eye of the needle, it needs a careful adjustment to align it. I do mine by using a magnifying lamp to aid viewing the mechanism, then holding the needle threader down level with the eye, gently manipulate the hook until it is able to move into the eye., usually a tiny amount either side. If it needs adjustment vertically, then it needs the small screw carefully undoing a little, until the threader can be moved slightly up, or down.
Mar 19, 2017 | PfaFF Sewing Machines
The needle threader on my Janome 6260 quit working. The needle is inserted correctly.
Is the threader broken or just not meeting the needle eye? If broken, it can most likely be repaired.
If the threader is not meeting the needle eye, adjust the needle height so the threader meets the eye and intercept the thread. I have a 60's machine with a threader that needs the needle height manually adjusted because the needle does not stop in any particular place. Usually, if I raise the needle to its highest, the threader will work.
Oct 06, 2016 | Janome Sewing Machines
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
My automatic needle threader doesnt line up with the eye of the needle
possibly the wrong needle length then . have never needed one myself .
Sep 24, 2015 | Sewing Machines
Needle threader not threading
1. LOOK TO SEE IF YOU HAVE THE WIRE HOOK ON THE THREADER. THIS IS A VERY SMALL WIRE THAT GOES THROUGH THE EYE OF A NEEDLE. 2. IF IT IS MISSING THEN UNSNAP THE OLD ONE AND REPLACE IT. 3. CHECK TO ENSURE THE NEEDLE IS AT IT'S HIGHEST POINT. 4. LOOK CAREFULLY TO SEE WHERE THE WIRE HOOK IS GOING TO (TOO HIGH OR LOW). 5. ADJUST THE THREADER UP OR DOWN TO CAUSE THE WIRE THREADER TO GO THROUGH THE NEEDLE EYE. ADJUSTING IS DIFFERENT FOR EACH MACHINE BUT YOUR USER'S MANUAL SHOULD HAVE THIS. ALSO, YOU CAN USUALLY FIND THIS ON YOU TUBE.
Jan 31, 2015 | Sewing Machines
Bernina virtuosa 155 solutions
Needle threader heads are actually easily replaced and should be replaced anyway every few years because they do wear-out. Get a magnifying glass and, having returned the needle to the top (use the foot controller, so that the machine stops it in the right place), pull the needle threader down until the head rotates towards the needle. Look with the magnifying glass to see if the small hooked part in the centre of the threader head (the light grey plastic part) goes through the eye of the needle - if not, you might be able to bend it VERY carefully so that it does - that should cure it. If the hook is a long way above or below the needle eye, dont try and bend it, the cam that rotates the threader has probably moved on the needle bar and will need adjustment by a service agent. If the hook is passing through the eye of the needle OK, but still not pulling the thread back through when you release it - i.e. the thread is just slipping-off, the hook has become rounded through normal wear and you'll have to replace the threader head. The threader head simply pulls off - you might need to carefully lever it off the round shaft. Replacing it is a matter of simply putting the new one on the shaft and pressing upwards firmly so that the grooves in the threader head go right up to the horizontal pin on the threader shaft.
Dec 12, 2011 | Bernina Virtuosa 160
I am not sure how to replace my broken self threader hook, to put in a new hook for my 2040 model, Pfaff sewing machine?
If your talking about the needle threader, it just simply slides on to the stainless steel shaft and snaps on. You might have to adjust it a little if it doesn't line up with the eye of the needle. To do that you need to remove the side cover of the needle bar area, and loosen the 1.5MM allen screw that sets the stop for the threader stop. It is located near the top of the needle threader bar.
May 13, 2011 | PfaFF Tiptronic 2040
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
Dec 03, 2010 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
