Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
I have a dell dimension l866r( i no it's old but, it's for my kids) my problem is i'm trying to reformat and for some odd reason it's not booting from the cd. i set the bios to boot from cd but, it's still not picking it up. can some1 help me plzz?
    Sniper:
  • 89 Answers
Unless something's wrong with your CD drive hit F12 on the keyboard when the computers turning on it should give you a list of devices to boot from one of them should be CD
Posted on Jul 27, 2009
How do i reformat my dell dimension e521 computer
The easiest way is to boot from the Windows installation CD and select format hard drive.
Jan 17, 2012 | Dell Dimension E521 PC Desktop
How do I reformat a Dell dimension 8300, it will not do anything after inserting the operating system disk
You need to make the DVD drive the first bootable device.
F2 on boot up should take you into the bios, it should say on the first screen as you boot what key takes you into the bios/setup.
Change the boot settings to allow the dvd drive to boot first.
It should now say press any key to boot from cd/dvd when you put your installation disc in
Sep 04, 2010 | Dell Dimension 8300 PC Desktop
Trying to reformat my DELL Dimension 4600-the wizard stops the process because SP 3 was added later--any ideas besides the old format c: command? nothing on the DELL site that I could find. Thank you in...
Go into BIOS Setup, (Dell's term is System Setup), and in Boot Options set the first boot device, to CDROM. Don't forget to Save Changes.
(After you see the Dell logo, {AND I mean IMMEDIATELY AFTER}, press the F2 key to enter System Setup)
Jan 22, 2010 | Dell Dimension 4600 PC Desktop
How can I fix Fdc failure when I switch on my Dell L866r desktop computer. I ask somebody to re booth my comp. after it was done this problem occur. Also how can I improve performance of my comp. Too slow.
hello, FDC error ( FDC Failure) is usually either improper floppy drive setup - check cablesare connected properly on the motherboard and and in to the floppy drive-inserted all the way in, not in reverse. insure that power cable in connected properly.
Bad controller on motherboard: not much you can do with that but go in BIOS and disable the floppy controller and make sure first boot device is set to hard drive or cd/dvd drive instead of floppy.
As far as performance is concerned your system only has 128 MB ram, i would suggest adding some more. Try crucial.com or ebay for good price should about 15$ 20$ for another 256mb or so.
Go tosystem tools and run disk defragger tool to defrag your hard drive.
download free tool called "tune Xp" and use defrag boot files.
go to start run and type in "msconfig", hit enter
in new open windows click on "startup" tab and uncheck all the application that you don't use everytime your computer starts.
NOTE: Make sure not to uncheck any anti-virus/spyware/firewall software you may have installed.
don't worry you are not deleting anything but just removing things from startup to speed up startup process.
system will require reboot at the end.
i hope this helps, let me know if you have any other questions.
good luck
regards
Amar Sondhi
Dec 06, 2009 | Dell DIMENSION P3/866MHZ 128MB 20GB DVD...
My Dell Dimension 4600 needs to be reformatted. The Dell reinstallation OS disk boots up and gets as far as "Windows Setup....press Enter to continue". Then it freezes. I have tried using both the original...
Before you go ahead and try reformatting the system , Please disconnect everything from the system (Except Mouse, Keyboard and screen)
and then try to use the disc to reformat the system. and if it still hangs up or freezes up that clearly seems to be a hard drive failure.
Hope this help.
Cheers!!!!
Jul 16, 2009 | Dell Dimension 4600 PC Desktop
I am replacing the hard drive in my Dell Dimension L866r
Do you have a floppy drive in the drive if so remove it. Also turn off your floppy drive or just remove it completely it could be bad sending false info to the main board saying there is floppy drive in the computer. Also try and turn the drive off in the BIOS
Jan 16, 2009 | Dell DIMENSION P3/866MHZ 128MB 20GB DVD...
Start up problems
Normally, when the Dimension L-series gives a Press DEL to continue, it is an indication that the Hard Drive (Where data is stored) is failing.
At the Dell Screen when the system is 1st turned on, press CNTL+ALT+D to run a quick diagnostic on the hard drive. If there is a failure, you will get a failure code (Code 3, Code 4 etc) if the drive passes, no failure was detected (Doesn't mean one doesn't exists though)
To run more diagnostics, you can boot to the Dell Dimension Resource CD if you have it and run Dell Diagnostics from the CD.
May 12, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Jan 28, 2008 | Dell Dimension 3000 PC Desktop
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
398 people viewed this question
Alun Cox
