Question about Intermatic Hardware & Accessories
I have the malibu intermatic m200rt. When the timer turns on the low voltage lights they light up than shutoff for a period of time come on again and shut off again.
  • Intermatic Master
  • 5,245 Answers
Following link has troubleshooting resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Nov 09, 2017
  • 3 Answers
SOURCE: Malibu ML200RT low voltage power pack is not working
First check to make sure that you do not have more watts pulling than is recommended. If this is ok then pull both the red and black plastic pin from the timer and replace them then try. If neither of these solutions work you may have a problem at power source.
Posted on May 10, 2009
gotgeek2
  • 565 Answers
SOURCE: Replacement of on/off trippers for intermatic low voltage timers
These should work:
http://www.nextag.com/timer-trippers/shop-html
Posted on Jan 02, 2010
  • 5481 Answers
SOURCE: I have an intermatic/malibu low voltage outdoor
I think you can add any Malibu 12V lights rated for the 300 W power pack. Make sure that the total output stays below the 300W limit.
http://www.malibulights.com/ and click on Products and the different available lights will be detailed with the voltage and wattage.
You just have to click on the category, then the specific light and Product details.
This tier light would be acceptable http://www.malibulights.com/Products/Detail.aspx?category=Low+Voltage+Lighting&subcategory=Tier+Lights&sku=8301-9200-01&series=TIR-2009-1&seriesname=Cast%20Metal%20Tier%20Light&id=195
This flood light can also be put on the system
http://www.malibulights.com/Products/Detail.aspx?category=Low+Voltage+Lighting&subcategory=Flood+Lights&sku=8301-9602-01&series=FLD-2009-2&seriesname=20W%20Cast%20Metal%20Flood&id=206
I hope this helps.
Posted on May 10, 2010
gotgeek2
  • 565 Answers
SOURCE: Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer: I've had malibu lights for around 4 years,I have ...
If other lights are working the power pack is OK. Usually, as in your case, if changing the bulb doesn't work, check the connection where the light ties into the main run.
Posted on May 21, 2010
SOURCE: My Intermatic Timer (model PB115M1) is not keeping
...may have solved this one... opened up an Intermatic Model HB31R and it seems to have the WG2030 timer motor... this model (complete timer box) cost $20 or so...
Posted on Sep 24, 2010
Manuals al900mtss transformer
Copy following link for Intermatic / Malibu low voltage transformers manuals:
Copy following link for Low voltage Intermatic pool transformers:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool-lights
Jun 05, 2012 | Intermatic Hardware & Accessories
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
I just replace a light (not bulb) in my Malibu low voltage lighting system. That new light did not work and now all of the rest of the lights past this point no longer work. But the lights between this...
Working with the bulbs can cause other bulbs to go out.
Malibu suggests turn power pack off when replacing bulbs.
Also connections get loose and need to be re-attached.
Open following link for Intermatic/Malibu power pack resources.
Upvote the help.
May 29, 2011 | Malibu Intermatic Inc. ML121RT Low...
Lost black pin for ML600TW Malibu low voltage transformer
You can go to the Intermatic web site;
http://www.intermatic.com/
Click on customer service and then the tripper order form
or try this direct link to the form:
http://www.intermatic.com/~/media/Files/Intermatic/Other/866%20tripperorderform_6%2014%202010.ashx They're only about 10cents each so buy pleanty.
Jul 12, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Clock does not work,manual operation turns light on
You posted under Intermatic-malibu power packs.
There are no replacement clock motors.
Improvise by setting timer to override and plug power pack into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Jul 11, 2010 | Malibu ML200RT - Low Voltage Power Pack...
May 17, 2010 | Malibu Intermatic Inc. ML121RT Low...
I have an intermatic/malibu low voltage outdoor timer. I wish to add lights, but the only number I can find is 154LV24409
I hope this helps.
May 10, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
I have a Malibu 600 watts low voltage transformer that works only for 30 minutes and then, will turn on again for another 1 hr. I only want to turn on one time but for 4hrs. I already removed one red and...
There are no repair parts for intermatic/malibu power packs.
If problem timer malfunction, then set power pack to override, buy cheap plug-in timer, and plug power pack into cheap timer.
If problem is internal wiring, then replacement is option.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Sep 01, 2009 | Intermatic Malibu 300W Power Pack...
Hardware & Accessories Logo
388 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
