Question about Dryers
What does the E1 error mean? - Dryers
    Sergeant:
  • 222 Answers
E1 means: Thermistor Failure. You will need to replace this.
Here's the thermistor for your model you can order:
Thermistor 8577274
You would need to take off the lower front access panel under your door, then take off the duct assembly#45, by removing the two #32 screws, and remove the #2 screw at the very bottom of the duct assembly with a bracket#11 attached to it, remove that one also. Unplug your dryer first! Then your thermistor is #42 on the blower housing, next to your thermal fuse#59.
Posted on Aug 09, 2017
2 Suggested Answers
Karthik316
  • 187 Answers
SOURCE: Error E1 mean?
An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced.
http://www.appliance411.com/data.php?rc=548392
pls rate my suggestion...
Posted on Jun 26, 2009
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What is a E1 error
    In some Dishwashers it means slow draining time. Can mean the drain hose is kinked somewhere. But other models have other meanings Just type in E1 error and your model it will give you a plethera of information.
    Oct 02, 2014 | Dishwashers
    My air conditioner want turn on or anthing and it shows e1, whats this mean
    The E1 code is an error code that appears on the LED temperature display of some digital air conditioners. The error code could mean anything from dirty air filters to a damaged room thermistor, a safety connected to your thermostat that detects room temperature. Troubleshooting the cause of this error code may improve your air conditioner's performance
    Sep 15, 2013 | Haier HWR06XC7 Air Conditioner
    Dometic model 3313192 thermostat error code E1 what does this mean?
    Hi By E1 error it means
    Loss of communication between the Single Zone LCD thermostat and the module board. LCD will cycle between E1 error.
    Check the link for regular maintenance Of the LCD thermostat.
    If it doesn't help then you have to replace the LCD thermostat.
    Ajin
    http://www.google.com/url?sa=t&rct=j&q=dometic%20model%203313192%20&source=web&cd=1&ved=0CCwQFjAA&url=http%3A%2F%2Fmanuals.heartlandowners.org%2FHeating-Cooling%2FA-C_Units%2FDometic%2FDometic_Single_Zone_LCD_Thermostat_Operating_Instructions.pdf&ei=hOg0T7OUNIjkrAer4Ny6Dw&usg=AFQjCNEn2y9-ItUcF2KRJZ0dm0Ftrq8Jhw
    Feb 09, 2012 | Dometic Rooftop RV Air Conditioner
    What does error code #e1 mean on Canon CLBP 460 PS mean?
    Meaning of error code E1
    The motor sensor or sensors, the DC controller on the main board DC controller.
    I can not give solution to your problem, because possibility of damage main board.
    I suggest you contact Canon Customer Support (e-mail, telephone, or repair contacts).
    Nov 16, 2011 | Canon CLBP 460 PS Laser Printer
    Hi Mr. Janome expert, My Janome Memory Craft 4900QC is showing error message E1.Unfortunately I lost the manual to identify the solution to this problem. Could you mind telling what this error means...
    E1 means it out of order--something in the electronics is mess up--it needs to be serviced
    by a service tech with the tools to check the electronics of the machine
    Sep 13, 2011 | Janome Memory Craft 4900QC Mechanical...
    Error code E1 what does it mean
    The problem is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in troubleshooting this error code.
    Troubleshooting Error Code E1 on Whirlpool Duet and Kenmore Elite Dryers
    Aug 27, 2011 | Kenmore 62602 Electric Dryer
    Error E1 mean?
    Jun 26, 2009 | Whirlpool Washing Machines
    Error Code E1
    replace the thermistor
    Dec 20, 2008 | Kenmore Elite HE4 Electric Dryer
    I keep getting the error "E1" & the dryer turns off ...what does that mean?
    I've read in other forums that E1 means the thermistor has failed. As far as I understand, it monitors the temperature of the air that is leaving the dryer and entering the dryer vent. If you're not handy, a service call is in order.
    Mar 24, 2008 | Kenmore Elite HE4 Electric Dryer
    Dryers Logo
    Top Dryers Experts
