Question about The Office Equipment & Supplies
SOURCE: light flashing printer no print
unplug the (USB or Parallel) cable of the Printer from Printer backside which is connected to the Computer
open the top lid of the printer and check whether the carriage comes to middle or not?
It it moves automatically, then its fine.
Check the cartridges.
click the URL Link giveb below it will open a webpage. If it does not open a webpage then please copy the entire link and paste it in the address bar of the internet browser and click on "GO"
HP Deskjet 800 Series Printers - Fixing Blinking Lights
HP Deskjets - What are the front panel lights and buttons on the 800 series printers?
Check the End of warranty date on both the cartridges.
Deskjet 882c printer does not support reserve mode printing.
Means, even if only cartridge is defective or expired the printer will not print with other cartridge which is fine.
Both the cartridges should in inwarranty and fine.
Shake the cartridges well
With the color and black cartridges touch a clean, slightly damp cloth (squeeze out excess water),
to the printer nozzle area on the print cartridge, to see if you can make the ink flow freely.
Be careful not to touch the nozzle area (with holes on it) on the cartridges.
Wipe the copper-colored electrical contacts with a clean distilled water or clean tap water and then with a dry lint-free cotton cloth
Also using a new swab, clean the electrical contacts inside the printer, in the carriage.
Install both the cartirdges in the printer, disconnect the printer from the computer and try to print a self test and diagnostic page
Running a sample page
Turn the printer on.
Press and hold the RESUME button until the printer starts printing.
Release the RESUME button.
Running a diagnostic test
Press and hold the POWER button.
Press the RESUME button four times.
Release the POWER button.
Posted on Nov 20, 2007
  • 74 Answers
SOURCE: Urgent: red light error on Epson Stylus CX3650
It appears that this is an overseas model (at least for those here in the US that is) as far as I can tell. This will use the same drivers as the CX3600 model though. Depending on how long you have had this and how often you use it, you may have a waste ink reset situation. While I have not had any personal experience with this model, there are several references on the internet on how to do a reset. There is even an "SSC Service Utility" you can search for that lists this printer as being supported. It cannot reset the ink counters but it may reset the waste.
Good luck, I hope this is of some help.
Posted on Oct 18, 2008
SOURCE: Yellow light on and won't print on Dell model 1110 Lazer Printer
Dell printers are the worst I have worked with, this problem may be a 'paper jam' when there is no paper jam at all (or one REALLY stuck on the fuser). Check on the back of the printer for a piece of paper jammed on a sensor.
Posted on Dec 14, 2008
  • 84 Answers
SOURCE: Flashing lights and no printing
If the two lights are blinking persistently and the carriage is moving freely when the cover is opened then the logic board has problem and should be replaced. However, if there is some restriction of carriage movement or cracking noise, the optical cable should be replaced. Good luck
Posted on Apr 29, 2009
  • 2306 Answers
SOURCE: Canon S630 Printer. Yellow light blinks 7 times, green once.
7 Blinks says that your printhead has gone out. Just needs a new printhead, QY6-0034-000. around $40.00
Posted on Aug 08, 2009
Printer does not work-brown light instead of green
Check the que for that printer. Clear all print jobs and try to resend.
Oct 16, 2014 | Dell 1130 Laser Printer
HP920c cartridge light wont stop blinking, printer wont print
Please refer below for detailed troubleshooting of the specific condition:
PRINT CARTRIDGE light RESUME light POWER light Blinking Off On c00106873.jpg c00106862.jpg c00106865.jpg Problem
The printer top cover is open, or there may be something wrong with the print cartridge.
  1. Close the printer top cover.
  2. If the PRINT CARTRIDGE light continues to blink, continue with the following steps:
    1. Open the top cover. The print cartridge cradle will move and then stop.
    2. Locate the yellow arrow on the top of the print cartridge cradle. The yellow arrow points to a drawing of a cartridge that represents a symptom. Perform the task associated with that symptom.
    3. For a list of symptoms, refer to How to use the cartridge drawings under the top access door on a 900 series Deskjet .
May 12, 2010 | HP DeskJet 920c InkJet Printer
I960 resume light flashes yellow 5 times 1 green
Five yellow flashes indicate that the printer doesn't recognize the print head, or thinks that the wrong print head is installed. You can try to remedy this by opening the cover, removing the ink tanks, then removing the print head (lift the locking lever). Check that the copper contacts on the back of the print head are clean, then reinsert the print head, lock it in, and reinstall the ink tanks. If you still have the error indication, the print head may be bad and need replacing. Contact Canon for your options on this.
Feb 05, 2010 | Canon Office Equipment & Supplies
Light flashing green and yellow will not print
Hi this is only a try it may work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 14, 2010 | Canon i850 InkJet Photo Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Print head problems 7 yellow lights 1 green light, how do I fix
That's not a printhead problem, it's saying that the waste ink absorber is full. You need to have them replaced at a shop where they can also reset the waste ink counter.
Apr 13, 2009 | Canon i850 InkJet Photo Printer
Flashing green light prevents printing.
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Canon pixma ip1300
cannot print on blinking pilot light green and yellow
Jun 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
