Question about Plumbing
The faucet drips constantly from a single handle tub. How do I fix this?
  • 2,992 Answers
NO.. no no no... Don't smash out all that tile
and granite just yet
(Welcome to fixya) an obviously open...
TOTALLY FREE... all volunteer website.
Hello Donna Taylor,
The reason this site is called FIXYA... is because
there are a few of us left here that KNOW valves
can be fixed... (especially OLD brass things).
If you valve is 20 years old... AMERICAN STANDARD,
DELTA, MOEN or PRICE-PFISTER... you probably
do not have much to WORRY ABOUT.
Parts and kits abound.
VERY SAGE words of advice... close the drain
BEFORE DROPPING that screw, spring or cap...
Delta (ball type) single handle do INDEED
have SPRINGS... and they WILL fit right
down that drain... Have a look on eBay...
Delta single hanle repair kits eBay
Sites and opportunities to do your job fast,
cheap & quick abound...
Pay no attention to the "PLUMBER"
with the sledge hammer & crow-bar...
Be GENTLE and ALWAYS KEEP your old parts.
New... modern... imported faucets MAY provide bigger
CHALLENGES... but that is why of FEW good
PLUMBERS stop by to help...
In the case of bath/shower controls..
OLDER is better (especially BRASS).
Comment me back with NAME on handle
I can do better... FREE)
Look around...
eFAUCETS.com, faucetsdirect.com
http://efaucets.com/
faucetsdirect.com
Great Savings on Faucets Sinks and More for your Home Kitchen or Bathroom
Price-Pfister "stem" (Ace brand (from eBay))
Ace 45494 Cartridge for Price Pfister Avante Single Handle Faucets FREE...
SAME BRAND faucet... in DANCO
(plastic parts (hey... it works))
ACE 45494 Cartridge for Pfister Avante Single handle Faucets
MOEN...
Lot Of 5 Danco Repair Kit For Moen Single Handle Faucets Model No 86647...
Moen Single Handle Faucet Adapter Kit Repair Kitchen Bathroom Replacement...
Not to mention just taking the "actuator" in hand and
going down to the GENERAL PLUMBING SUPPLY
store (show & tell).
Fixing things is the ULTIMATE in recycling
(besides... MODERN VALVES are cheesy plastic
(in my opinion))... I like to shower & GET OUT.
Hope this helps... I'm here daily (FREE).
Carnac the Magnificent
Posted on Jan 11, 2018
    Scholar:
  • 190 Answers
We would need a little more information but sounds like it will need replacement, The water will eat up the meatle and make a rebuild impossible sorry but no quick fix the hot water lineis usley the culprit
Posted on Jan 10, 2018
  • 659 Answers
SOURCE: replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Posted on Apr 03, 2009
jj505
  • 195 Answers
SOURCE: single handle pull out Franke faucet stopped working
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 5 Answers
SOURCE: Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Posted on Dec 27, 2009
radar001
  • 1051 Answers
SOURCE: How do I repair a leaky Moen faucet handle. When I
It needs a new cartridge. Moen gaurantees most of their products for life, so if you have the original instructions check for contact info. They'll send you a new cartridge for $0.00
Posted on Jan 14, 2010
motor1258
  • 6674 Answers
SOURCE: how do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Posted on Jan 22, 2010
Can you put new rubber gaskets in a single handle bath tub faucet to fix a drip?
Depends upon the design. I have repaired Delta faucets using parts provided in a kit.
May 18, 2017 | Home
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
The faucet drips and I cant figure out how to make it quit.
It can be repaired without taking entire valve out of wall. First shut water off and remove handle. Next you will see a collar that will screw off to remove the cartridge below is a link for a single handle moen faucet. Check it out to get an idea. If you know your model you can research on line ,but they are close enough to give you an idea.
Once appart replace washers or o -ring's. Pay attention to how you take it appart for easy reinstallation.
http://www.moen.com/shared/pdf/t2703pt.pdf This link is aparts breakdown of a single handle faucet.
http://www.moen.com/shared/pdf/t2703pt.pdf This site is installation instructions.
http://www.efaucets.com/detail.asp?Product_Id=T2703 This site you can enter you faucet model to retrive information.
Jun 19, 2010 | Moen & One Handle Tub & Shower Faucet
When I push the faucet to off I get med fast
push down the tub-spout lift rod and it will empty the remaining water that is between the shower valve and the tub spout
Mar 10, 2010 | Moen Posi-Temp Single HandleTub And Shower...
New moen one handle shower faucet drips
sound's like you either have some debris caught up in there, or you might not have your handle on correctly. give that a try .
Jan 23, 2010 | Moen & One Handle Tub & Shower Faucet
How do I fix a dripping MOEN T4572 lavatory faucet
No charge.
Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
Tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Nov 09, 2008 | Banner Faucets Pro Series M580 Single...
Plumbing Logo
135 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
