I am looking for the codes on my Cineplus television?
Cineplus Tv and need to program prima remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
May 18, 2016 | Prima Televison & Video
Cineplus remote codes
021,029,026. Try these codes. If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls.
http://electro-medical.blogspot.com/
Dec 29, 2013 | Televison & Video
Prima Cineplus 50" Plasma PH-50R18C will not turn on
The ambient temperature might be high. Check whether the foolinf fans are working or not. If not, check out the reason for it. The TV must be placed at least 6cm away from wall, and should have sufficant ventilaation.
Nov 15, 2013 | Televison & Video
How to open child lock on cineplus LG TV manually as remote is not working
Try entering code 0000 or 1234 for the child lock.
Otherwise try holding down the DISPLAY key on the remote or on the front of the tv for 10 seconds to disengage the child lock.
Jan 28, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a lg cineplus model RF-20CA30K. Sometimes tv screen goes black and then flash like on/off, then i push to him with my hand and screen goes normal. What is the solution
Aug 15, 2010 | Televison & Video
Program prima tv remote
prima lcd tv:lc-27w25s auto search passward
Mar 15, 2010 | Primax Electronics HT2778P TV
I have a prima 32'' cineplus lcd tv and its not turning on red light blinks on and off and nothing.
Most likely a problem with your power supply. Have a certified technician check it out.
Nov 02, 2009 | Televison & Video
Cineplus tv, loud popping sound, no picture? Warranty co. gone!
having a hard time turning on my Cineplus LC-32R25C
Cineplus 32” High Definition LCD Television...when i hit the power button..thered light on tv goes to yellow..as it it was in sleep mode..and i dont know wat to do to get it out of that state to turn it on..is there a sequense of buttons on the remote i gotta push to get it to work?
Sep 13, 2009 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
