Question about Hardware & Accessories
I have a Utilitech #0141224 installed, but the display doesn't light up. How do I change or replace the internal rechargeable battery?
  • 5,245 Answers
Modern timer batteries are built into the circuit board and not replaceable ... sounds like a different problem since battery is back up carryover for power outage.
Push override and see if load operates.
Troubleshoot resources and manual:
Posted on Oct 30, 2017
4 Suggested Answers
  • 760 Answers
SOURCE: Can the Utilitech Mode #
I believe it is a single pole only, and also requires a neutral to operate.I'm assuming it has black(line) red(load) white(neutral) green(ground) If you need a three-way or only have a switch leg in your box (no white wires) then I'd recommend one of intematic models that can be connected either as a single pole or 3way and requires no neutral.
Posted on Aug 13, 2010
SOURCE: RE: Utilitech 7-day in wall
1) Utilitec timers cannot be used for multiple switch replacement.
They replace only single-pole switch.
2) Open following link to see specific timers that can be used for 3-way.
3) In your case you have 3 different switches that control outside lights: so you have two 3-way switches and one 4-way switch.
Open following link to see typical 4-way wiring.
4) 3-way timer will replace one of the 3-way, but not the 4-way.
The timer can be used in place of the 4-way switch.
Identify 4-way because it has 4 screws and 4 wires (excluding ground wire)
5) Keep in mind that 3-way timers replace one of the 3-way switches.
But wiring has to be changed at the remaining 3-way switch.
Open following link to read why wiring is changed at remaining 3-way:
Wiring at the 4-way switch is left the same.
When you buy the timer, read manual carefully for correct wiring, or add a comment to this thread, and I will help more.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 24, 2011
SOURCE: I have installed a Utilitech
You are replacing single-pole switch, then 0141224 is correct choice.
It sounds like your have wiring wrong.
No jumper is needed from other switch, all you need are two wires from replaced switch plus a neutral wire.
Open following link for detailed wiring instructions and online manual.
Add a comment and ask about particular part of manual or wiring if needed.
Posted on Apr 20, 2011
Utilitech TM029 manual needed
Copy following link for TM029 aka LW60418/ 0141224:
Add a comment and describe timer in detail.
Sep 20, 2013 | Hardware & Accessories
Utilitech wall timer
Utilitec timers do not have replaceable batteries.
Older timer designs have batteries, while more modern timers have internal rechargeable battery that is integral with circuit board, and cannot be replaced. The battery holds memories in event of power outage, but current time must be reset if power is out for extended time.
If you have continual problems with failed timers, then have electrician friend run test on your power for spikes, shortages and surge that will cause timers and other non-hardened electronics to fail frequently. Also check for polarity and grounding issues. Also if you have motors, other electronics and/or fluorescent lights on same circuit, this can cause interference.
Also check load limitations, and load on timer to make sure you are not exceeding the timer rating. For example using timer to control motor when timer is rated for non-inductive incandescent loads.
Reset timer using reset button, and then re-program. Buy another timer at Lowes and return defect in new package for refund.
Buy Intermatic ST01C timer. This timer uses CR2 battery, and timer electronics operate separately from electric line. Rated for any load: motors, cfl bulbs, led, incandescent, etc.
Add a comment
Jul 18, 2013 | Hardware & Accessories
My light dont come on when im pushing the trigger
The internal control unit will not let the bulb operate if the battery is not up to voltage. To recharge the battery, you will need a 12VDC 300mA adapter. It will take 12 to 15 Hours to charge. If that doesn't work, replace the battery
Sep 22, 2012 | Vector 1 Million Rechargeable Spotlight
I have installed a Utilitech timer switch #0141224 on one of three switches. The switches are all in a row but I only want the last (rightmost) switch changed out. Do I need a jumper from switch 2 to 3? ...
Apr 20, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I'm trying to program a utilitech timer with no instruction book
Try following page:
Page has links to Utilitec manuals and programming steps.
Also add a comment and say exactly which buttons are on the timer, or what timer looks like, and I can probably identify timer and provide instructions.
Dec 30, 2010 | Hardware & Accessories
I bought Utilitech #0141224 7 day digital in wall timer. I have just 2 wires at the junction box both of which are painted over but assume one could be black and other white. The 7 day digital timer...
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
M Jones
Sacramento, CA.
Aug 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
359 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
