Question about Baby Gear
Is walmarts ares8 with blue buttons instead of black a newer version that Amazon's area 8 that has 2013 in the setup menu????
Amazon ares8 has 2013 in calendar setup!!! Walmart has blue buttons instead of black! Is walmarts newer????
jigsawbill
  • 398 Answers
SOURCE: Purchased HP Deskjet D1520 at
Go to HP.com and click on support, they should be able to help you out, and if necessary they can do a warranty deal.
Posted on Aug 04, 2008
ginko
  • 19396 Answers
SOURCE: Sanyo DP42746 - Screen went black and no sound. Power light on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Jun 16, 2009
  • 3 Answers
SOURCE: WPDVD-296 purchased at Walmart. Walmart referred
With no disc in the player
1) turn on.
2) press open key.
3) press 5168.
4) select rating.
5) select "adult" or whatever rating you would like.
6) select setup.
Posted on Feb 02, 2010
  • 101 Answers
SOURCE: dell vostro 220 just went
So, you already reinstalled XP on this desktop?
Posted on Aug 15, 2010
  • 252 Answers
SOURCE: why will my walmart.com not
Without knowing your network setup, I can list a few general ideas.
First, try powering off your Cable modem and disconnect all cables to it and unplug it for about 1 minute. Then reconnect the power. After about 30 seconds, reconnect the coaxial cable (thick black round cable with the wire sticking out) and screw it on tight. After about 30 seconds, reconnect the network cable from your cable modem to your router uplink port (if it has one...some newer routers have automatic uplink detection).
If that doesn't fix it, you make have to call tech support at Time Warner so they can register your equipment in their system.
Posted on Apr 13, 2011
How to unlock a Toshiba blue-ray DVD player bdx2150 to all regions Please help Thanks
If the current firmware in your blu-ray player supports multi region then try this.
1. Power on the blu-ray player.
2. Press "Setup" on the remote to enter Setup Menu.
3. Using the remote, enter "8520". A new submenu will appear.
4. Set DVD region code to "0" for DVD Multi Region.
5. Set BD region code as required using the remote buttons.
"1" = Region A, "2" = Region B, "4" = Region C
6. Press "Setup" button to exit the menu.
If this does not work then try upgrading the bluray firmware.
Search for Toshiba BDX2150 firmware and see if there is a newer firmware than the one you have installed.
Nov 05, 2017 | Toshiba Televison & Video
Instead of black basic color
You need to enter maintenance Mode by pressing the following buttons in row in less than 2 seconds
Menu Star 2864. Then press 76 and then 6 and then press the right arrow until the monitor displays Black. Then press MONO Start and the machine will heavily clean Black
Nov 24, 2015 | Brother MFCJ615W AllInOne InkJet Printer
HOW DO I ACCESS AMAZON PRIME WITH MY SAMSUNG BLUE RAY PLAYER? THERE IS NO PRIME APP ON MY BLUE RAY PLAYER? PLEASE ADVISE OR I WILL CANCEL THANKS
Try updating your apps and firmware on the Blu-Ray player from the setup menu. However if it is an older player the Amazon app may not be supported.
Dec 10, 2014 | Samsung Televison & Video
Why is my airconditioner blowing hot air instead of cold... we tookit out for this year and now it dooesnt work right do we add freon to it
Check the capacitor, It should be flat on top where the wires connect. A lightening strike or other power surge will cause this area to be puffed up. two wires connect either way. Three wire, Black to common Red,white or yellow to herm, Blue purple or brown to fan.
Jul 27, 2014 | General Electric Heating & Cooling
How can I install Amazon Cloud Drive?
I would be tempted to uninstall (using control panel) and try using One Cloud from Microsoft or Google's version (can't recall the name off hand).
May 13, 2014 | Amazon Cloud Drive Photos
I Lost picture. Went to press mute button on remote and pressed last button instead. Now i can't get picture back.
If you hit the "last" button again, it should take you back to the channel you were on before you hit the button. when you lost the picture, was the screen blue? black? If you hit the "menu" button, does the menu come up?
Jan 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Why will my walmart.com not go through I switched to warner cable instead of att and put va router on and can not get my walmart associates log in to go through
Apr 13, 2011 | Microsoft Windows Vista Ultimate Edition
Cant get windows installer and java to open even after downloaded
Method 1
Unregister Windows Installer, and then reregister Windows Installer. To do this, follow these steps:
1. On the "Start" menu, click "Run:.
2. In the "Open" box, type "msiexec /unreg", and then press ENTER.
3. On the "Start" menu, click "Run".
4. In the "Open" box, type "msiexec /regserver", and then press ENTER.
Method 2
Upgrade to Windows Installer version 2 or newer version. To do this, follow these steps:
1. Start Microsoft Internet Explorer, and then browse to the following Microsoft Web site:
http://msdn.microsoft.com/downloads
2. In the left pane tree menu, click "Setup and System Administration", and then click "Setup".
3. Click "Windows Installer", and then click the appropriate link for your operating system.
4. Click "Download" to download and install Windows Installer version 2 or newer version.
Method 3
Use Windows Installer CleanUp Utility to uninstall the failed product.
Description of the Windows Installer CleanUp Utility
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
Method 4
The Windows Installer service may disabled on the machine.
1. Go to "Start" -> "Run" , type "services.msc" and press on "Enter" button.
2. Double-click on the service named "Windows Installer".
3. Check the value in the "Startup type:" field. If it's currently set to "Disabled", then this is the
problem. Change it by selecting "Manual" from the drop-down box.
courtesy:- support.microsoft.com
Nov 01, 2009 | HP Computers & Internet
Getting error 1628
May 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Re-set 'Video Setup Page' in Main Setup Menu
hi kevin, just did the same thing, have u figured it out yet?
thanks
tim
Dec 20, 2008 | Audio Players & Recorders
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
