Question about Home
Smoke alarm removed still beeping has a new battery
    Top Expert:
  • 25,352 Answers
Time to replace it.
Posted on Aug 09, 2017
greg_margo
  • 1959 Answers
SOURCE: smoke alarm beeping
If after replacing the battery the alarm is still beeping, the smoke alarm is bad and needs to be replaced. Hope this answers your question. Best of luck!
Greg
Posted on May 23, 2009
TeaCii
  • 90 Answers
SOURCE: Smoke alarm keeps bleeping
Here are the steps:
Was this always like this? If not, change the batteries, clean it up. Consult the local fire dept. The help for free.
If that does not work, you will need to get it serviced/repaired.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
  • 50 Answers
SOURCE: 3 smoke alarms are beeping
usually the problem is battery,make sure that ur battery is not expired..try to reverse the battery like positive to negative then put it right..
Posted on Sep 07, 2010
  • 4736 Answers
SOURCE: smoke alarm beeps 3 times so I changed the
It may be clogged with dust. Remove the cover and blow it out with canned compressed air, like you clean a computer with.
Posted on Jan 15, 2011
mikadot
  • 2113 Answers
SOURCE: how to stop dicon smoke alarm beeping
All smoke alarms beep if the battery is too low. Getting a used battery isn't good enough for smoke alarms. Even getting a new battery from a dollar store (a cheap no name brand import store) will not do... it has to be the newest and it has to be alkaline. once you put it in... press the button for 10 seconds... first you will hear it's own alarm then you will hear the others attached to it in the whole system chime in (if you have that type) the alarm will now sit quietly.
Posted on Oct 20, 2013
HOW DO I REPLACE BATTERY ON FIREX FX1218
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
BATTERIES.
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
connections.
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 | Home
Smoke alarm won't quit beeping.
Check the date on the back of the smoke alarm. They need to be replaced about every 7 years. They also need to be cleaned once or twice a year, you can use a vacuum to do this. If they are older replace them.
Mar 18, 2017 | Home
My alarm beeps at night for a short period
if it is about a smoke alarm with a battery in it, when the alarm beeps for no apparent reason, it is a bult in indicator that the battery is flat or approaching a low voltage and needs replacing
If it still beeps after replacing the battery have it checked out as a fire alarm is critical for your safety
Jun 12, 2015 | Kidde 1276-9995 Hardwire Smoke Alarm with...
How do I stop smoke alarm from beeping
Smoke alarms beep in two different ways: it beeps continuously when smoke is present, and it beeps every so often (intermittently) when the battery needs to be replaced.
Feb 18, 2015 | Cars & Trucks
How to stop dicon smoke alarm beeping
Oct 20, 2013 | Home Security
My Kidde carbon monoxide alarm keeps beeping every 30 seconds and we have put new batteries in it but it keeps beeping
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon com smoke alarm detector (watch out on reviews). I hope this was helpful. cheers
Jan 09, 2012 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Lanson smoke alarm model LANSD240B S/N 139606 Alarm alert beeping. Replaced battery, tried 2 new battries, still beeps. No smoke or fumes found.
try this, remove the unit and take out the battery you will see 4 small rubber plugs in the back.
remove these and take out the 4 screws, you will find a lot of dust and insects in there, gently blow out with compressed air and the sensor as well.
I did 2 problem ones in my house and now they are working fine
Feb 18, 2011 | Vacuums
Kidde pe 120 photoelectric sensor smoke alarm emits 3 "beeps" with a pause and then repeats until the 9vdc battery is removed. The house is not on fire and the 120vac power is connected. What might be the...
The 3 beeps, known as temporal pulse, is indicative of an alarm condition. If it stops without a battery, then the unit either does not have power or is otherwise defective.
Jun 03, 2010 | Kidde PE120 Hardwire with Battery Backup...
Smoke alarm beeping
Greg
May 23, 2009 | First Alert SA302 Dual System Smoke...
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
