When I turn on my tv it has a black screen and says please wait
  • Televison & ... Master
  • 2,789 Answers
Hello Dolly Bates,
WELCOME to FIXYA...
(I checked your history in case you accidentally
disclosed the MAKE 7 MODEL (sometime in the past)).
The mere fact it says anything at all is a
REALLY GREAT place to start...
So...
While you are "waiting"... You could weigh your options:
Call your "service provider" (assuming you have one)...
or... Go to the YELLOW PAGES... (or YELP) & start searching form some SAMSONITE GORILLA to come into your house
and start knocking your TV set around...
or...
You could find your MAKE & MODEL...
(tell fixya... (FREE)).
Perhaps a little recent history (flood/thunder). Try to remember
what other devices you have connected... Disclose that you use BROADCAST, COMCAST... or live on the moon...
ALL THESE things could help literally Hundreds
of EXQUISITE volunteers... HAVE half a chance
to get INTERESTED in your PROBLEM...
JUST Not me...
I am old (rest of my day is booked (out of here)).
Free will still be FREE.
Carnac the Magnificent
Posted on Aug 09, 2017
4 Suggested Answers
  • 5 Answers
SOURCE: PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Posted on Feb 20, 2008
circuitworld
  • 335 Answers
SOURCE: tv turns on screen displays Please Wait then goes black
There's a problem with the power board communicating properly with the interface board aka 'main board'. There's seems to be a logic problem here _Data-Bus interference. This could be because of DC voltage shut down or an under-voltage condition on the power supply board. Also the serial data too and from the Timing control board could also cause a similar problem. You can send the power board and interface board too me and I'll repair the problem for you. Or if you have some test equipment I can show you what to test.
Get back too me when you can.
Please rate this answer :-)
Posted on Dec 05, 2009
gopakumarg43
  • 74482 Answers
SOURCE: tv turns on, says please wait, then goes black and nothing happens
The firmware to your TV might have corrupted. It should be upgraded.
Posted on Sep 11, 2012
Why my screen says please wait then goes black
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 05, 2014 | Dynex DX-LCD32-09 LCD TV
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
I have an Insignia NS-LCD37 was working perfectly fine, all of a sudden the TV went black, I would turn the TV on and you would get the
Most likely you have a fault in the back light circuit. To verify this, turn on the set, when the screen goes black, take a bright flashlight and shine it on the screen. It may be easier to dim the lights in the room so that you can see the faint image on the screen. If you see the faint image, you indeed have a back light problem. You will need to get a diagnoses performed on the set to track down the problem
Nov 22, 2012 | Insignia NS-LCD37 37 in. LCD TV
Tv turns on, says please wait, then goes black and nothing happens
Sep 10, 2012 | Dynex DX-LCD32-09 LCD TV
Dynex L26 10A purchased little less than year ago has audio, but black screen. When first turned on screen will display: "Please Wait", then screen goes black, but audio can be heard. Tried uplugging from...
Call for warrenty serviced,u still have warrenty inforced until a year.Ur tv have intermittently signal shutdown before it come throught the Tuner board not,carrying to the LCD Screen to produced a picture.
Jul 03, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Tv turns on screen displays Please Wait then goes black
Dec 05, 2009 | Televison & Video
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Black box on screen
Use the remote and turn off the closed captioning.Button is Usually maked cc
Please rate this a fixya
Feb 13, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
