Question about Samsung Kitchen Ranges
My Samsung oven doesn't come on. The broiler and all eyes work, just not the bottom. When turned on, the temp reads 350 then drops to 150?
aborcass
  • 2651 Answers
SOURCE: temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Posted on Oct 07, 2008
  • 126 Answers
SOURCE: Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Posted on Jan 07, 2009
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
  • 219 Answers
SOURCE: Gas oven won't light, but my broiler will, whats wrong?
could be a couiple things most common is the ignitor
Posted on Mar 25, 2009
localwonder
  • 6784 Answers
SOURCE: My kenmore gas oven won't heat. I turn to dial to
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Posted on Oct 22, 2009
My electric Samsung oven will not hold a temperature setting, especially on the bake setting. The oven seems to preheat fine and then when you put the food in, obviously the temp will drop because you open...
After finding a cheap one on Craig's and reading the problems I decided to roll the dice and buy this range. It has the exact problem described above. The owner had replaced the control module and temp probe with no luck. I hooked up the range and sure enough it would come up to temperature (let's say 350) then dropped back to below 200 and never recovered. Lots of relay clicking but no heat. I unplugged it, took off the back and sure enough, one of the connections to the bottom burner was burnt and the wire was laying in the bottom of the range. I cut the bad part off of the wire, added a new high temp stainless terminal reconnected and viola', it works fine now. Wonderful range for practically nothing. It took about 20 minutes to repair and cost $2.00 for the new terminal. Piece of cake. Take a look inside before you call someone. These terminals Samsung used are cheap, not crimped properly etc.... hope this helps! I'll change them all out tomorrow.
Jun 20, 2011 | Ovens
The oven seldom lights. Igniter is working, there's usually no smell of gas, burners and broiler are working properly, replaced dual gas safety valve with no help. When it does light, it won't maintain...
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 07, 2010 | Maytag Kitchen Ranges
Bake does not work but broiler does.
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The reason that the temp display reverts to 100 degrees is because that is the lowest default temp setting for the display and until the oven temp actually starts to increase, it won't change. So the temp display is working correctly for the BAKE function.
Here's a line drawing showing the part you may need. Ignitor Part # WB13T10045. The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGS905SEK1SS&productCategoryId=0124250&brandId=3272&modelName=GAS-RANGE&diagramPageId=00001&componentDescription=GAS%20&%20BURNER%20PARTS&documentId=G6090295&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you out and remember to disconnect the oven from the electric power before performing any repair work. Best regards!
Aug 01, 2009 | GE Profile JGS968 Gas Kitchen Range
Oven temp will not exceed 350 deg, also the timer does not work
Check the oven temp sensor with OHM meter. It should read 1100 ohms.
If not, replace it.
Otherwise the electronic control is bad.
Feb 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Eric Campion
Feb 15, 2009 | GE JBP30 Electric Kitchen Range
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Temperature control
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
