Question about Brother Sewing Machines
I want to purchase bobbin case for brother embroidery machine model NV950
  • Brother Master
  • 12,537 Answers
Your Brother dealer would have what you need. You can probably purchase generic parts from most sewing machine repair shops.
Posted on Aug 09, 2017
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
  • 46 Answers
SOURCE: My Brother Embroidery machine is
I would take it to a mechanic.
Posted on Oct 24, 2008
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
Mimito7
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
I need a schematic for a Brother 6700 embroidery machine. I cleaned the bobbin case and around it and now the machine is making lots of noise.
It is probably one of two things,
1st..always put the needle plate on before you install the bobbin case. You can lock the bobbin case down by putting the needle plate on after putting the bobbin case in. Take off the plate and remove the bobbin case, install the needle plate, then install the bobbin case.
2nd...your bobbin case may be damaged now, if it is scratatched or chipped get a new case.
Good Luck
Jun 30, 2017 | Brother Sewing Machines
Need part number for BOBBIN CASE for a Brother Embroidery Machine BE-1204C-BC-PC
May be quicker, easier, and less expensive to just purchase a replacement bobbin case. Bobbin cases are intricate and require a high degree of specs.
Feb 16, 2017 | Brother Sewing Machines
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
I just need to know where I can get the bobbin case for Brother Bicor VX1005. if not available, which bobbin case can be used in stead? I already checked ebay but I don't see it.
Contact your local Brother dealer or try the online Brother contact/support department. They should be able to provide you with the bobbin you need.
You can also try search some of the online sewing machine parts suppliers.
http://www.sewingpartsonline.com/
Sewing machines quilting machines embroidery machines vacuum cleaners...
Sep 23, 2015 | Brother Sewing Machines
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
When I embroidery bobbin jams
Please you buy a new model embroidery machine.
Jan 01, 2014 | Singer 5050 Mechanical Sewing Machine
Brother CS6000 computerized machine bobbin case moves and locks up
The Black bobbin case more than likely is not installed correctly.
The machine just won't sew with it rattling about in it's space.
Machines do have levels of quality. Proper maintenance is a must for any busy sewing machine who's owner is expecting a trouble free use.
Cheers,
Embroidery Services
San Diego, CA
Sep 10, 2017 | Brother CS-6000 Computerized Sewing...
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
Jun 09, 2012 | White Sewing Sewing Machines
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
