Question about Beyond Cell Phones
Voyager III won't move beyond Voyager III screen. I don't have a "yes" option to reset anything.
Rca Voyager pro
Maybe this:
Follow the detailed instructions below on how to completely reset your RCA Android 7 Voyager (RCT6773W22) tablet.
Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper. Release both buttons to reveal the Android bot on his back with a caution symbol above him.
Step 2. A new screen will appear asking you to use your volume up/down keys to move and the power button to select.
Step 3. Use the volume down (-) button to highlight "wipe data/factory reset." Once highlighted, select using the power button.
Step 4. A new screen will appear asking you to confirm your selection. Use your volume down (-) button to highlight "Yes -- delete all user data." Press the power button to select once highlighted.
Step 5. Once the tablet is finished wiping data, you may press the power button to select "reboot system now." This will restart your tablet.
Step 6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA 7 Voyager tablet.
Mar 08, 2018 | Pro Computers & Internet
My RCA (VOYAGER 3) DOS'NT RESPOND WHEN I TOUCH THE SCREEN?
Are there any signs of broken glass, deep scratches on glass or any signs of a physical damage ?
If there are no such damages, try to master reset the device by following the procedure below
Video guide : https://www.youtube.com/watch?v=ttvFDFqH5r0
Jun 07, 2017 | Cell Phones
I boughr my daughter a rca tablet model rct6773w22 she put a pattern lock on it and.dont remember what the.pattern to unlock.it is how.do.i reset it so it can be.used
you dont,thats why you write down those patterns,now you have to hard reset and lose your info,but,here ya go,
Apr 27, 2015 | Tablets & eReaders
Reset to original settings
Hello, Factory Reset is done by turning the phone off, holding the volume up button, holding the home button and then holding the power button till the phone vibrates and you can let go of the buttons. Use volume up and down to move through options and power button to select (don't have to hold, just press once). Select "wipe data" and then "factory reset". Select "yes" to delete all user data and wait for format to complete. Then power off then on and it should be back to original settings. Hope this helps.
Oct 21, 2014 | Samsung Galaxy S III S3 SGH-T999 4G White...
Virgin mobile venture won't start
Take the battery out. Then put it back in. I couldn't find anything that would work but doing a hard reset. Once I did that the phone worked again. I lost everything but my phone works again.
To hard reset the Virgin Venture please follow the instructions below:
Start with the phone turned off.
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    Note
    : You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    Note
    : The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
The Venture will reboot to the initial setup screen
Aug 10, 2012 | Virgin Mobile PCD Venture No Contract...
I have connected my PC to TV via S-video. Pc works fine, but tv displays just the background of my PC screen. Audio works fine. Please help. Thanks
So what exactly is wrong? It seems like you have dual screen enabled. Try mousing beyond the edge of you PC screen, the cursor may move onto the TV. If you don't want dual screen, there's an option for clone display instead.
Jul 15, 2011 | PNY 6200 512 MB AGP DVI + VGA + SVideo...
I have a dell XPS M1330 and its screen is loose. For e.g. if I am in a car / bus using my laptop, the screen tends to fall backward or forward. How can I tighten the screen?
I would try to look around the screen and see if there is any screws to tighten. Just try a few screwdrivers, and gently tighten the screws, with ought pulling to hard. If they are too tight, the laptop won't close. Don't be too invasive, if you have to take anything beyond the battery case off, you can screw up and destroy you hard-earned laptop.
Hope this helps!
May 27, 2011 | Dell XPS M1330 Notebook
Unit won't cool. Unit is set on is on cool, but warm air comes out. Is there a reset button on the unit ? Unit is 21 1/2 years old.
Some of those old Mach 3's have a manual reset pressure switch, but you will have to take the cover off to find it. Most manual resets have a red button to push to reset. The unit may be low on refrigerant or the condenser coil stopped up with dirt.
May 13, 2011 | Coleman Mach III Air Conditioner
Cell Phones Logo
73 people viewed this question
Top Beyond Cell Phones Experts
Techplus 2008
Computer Repairing
Computer Repairing
Tom Chichester
Are you a Beyond Cell Phone Expert? Answer questions, earn points and help others
