Question about Whirlpool Washing Machines
I have a whirlpool cabrio. I was getting un level codes during the spin cycle. Even with nothing in the washer. I changed the tub suspensi?n rods. Still getting same code. I found out how to get into the diagnostic mode for codes. No error codes. But washer still says unlevel. I went as far as putting a bubble level on the lid of the washer. Running out of options. Can anyone shed some light?
aborcass
  • 2651 Answers
SOURCE: No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Posted on Feb 23, 2008
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
  • 240 Answers
SOURCE: F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Posted on Mar 14, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
Posted on Mar 29, 2010
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
I have a Whirlpool Cabrio washer Model number WTW63003WO that gets off balance and displays a UL code.
It's important to check the level of the unit, and assure all adjustable feet are firmly planted on the ground first. A very common problem with these units are the suspension dampening rods, when they get weak they allow the tub to move around too much while spinning, and sometimes washing. A simple test by an experienced technician who knows what to look for would be to reach into the wash basket while the machine is empty and off, and push the tub all the way down till it stops, the technician will be looking for the amount of resistance it takes for this to happen. The easier it is to push the basket and tub assembly down to the end of it's travel the weaker the suspension rods are. At least one update to these suspension rods have been made, suggesting the current replacements are stronger. Part# W10247710, based on a model number of WTW6300WW0. Pleazer Appliance...
Apr 17, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
"2007 Whirlpool Cabrio HE top loader with glass lid" sat for 3 months, now it does everything except agitate, and flashes
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub. The image below shows how to remove the spin basket. If you unplug the washer and follow that procedure, you may find the cause of your problem.
Here is the document to help you.
Oct 14, 2012 | Whirlpool Cabrio Washing Machines
I have a whirlpool cabrio model wtw6600sw0 ans my washer tub is unbalanced and rocks bad. i have leveled the machine and evenly distributed the load! could there be something wrong with the tub or...
after you leveled the washer did you turn the locking nuts on the legs up against the bottom of the washer cabinet to keep the legs from vibrating back out of level?if you dont lock them they will change height during spin
May 06, 2012 | Washing Machines
I have a whirlpool cabrio washer WTW6600SW2. The washer makes loud thumping noise during spin cycle and then uL code flashes and it stops until you open the door. After moving the clothes around and...
ON SOME CAPBRIO IF YOU HAVE SOME LIME ONTHE WATHER THE TUB IS A FREE FLODING AND WILL GET STUCK ON THE UP POSICHONAND WOND GO INTO SPIN. TRY TO RUN A CLEANER YOU CAN VUY AT ANY BIG WALL MART. IF NOT TRY TO LIFT TUB AND PUT BACK DOWN . IT SHOOD BE VERY EASY TO PULL UP IF NAT YOU BEST BET ID TU BUY A NEW WASHER. PARTS ARE PRICY.
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
At the end of each spin cycle it knocks loudly
A Clothes Washer with the complaint of "excessive noise & sssshaking" can typically be a couple of things;
Un-level Washer (Very Likely) - I would level and adjust your legs on your washer appropriately. Make sure when your slighly "push test" your washer, you have no machine movement, rocking or tilting. When the machine is going into the final rinse/spin cycle, the tub can rotate fast and if the washer legs or even the floor is slightly un-level, this can result in your washer to become noisey, shake, etc and can further cause the unit to break-down and no longer spin.
Un-balanced Load (Likely) - Ensure you are loading the washer and distributing the clothes (weight) evenly as this may cause the tub to spin improperly at final spin cycle.
Broken Drum Support/Springs (Likely) - Can be 5" black supports located at inside - top of tub area. Also, springs can also be located at inside bottom rear of machine holding the tub to the rear panel.
-C
Fremont, CA
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
