Question about Cell Phones
Protection pin number pls - Cell Phones
Pls remove my pin i dont now my pin pls
try hard reseting your phone
Dec 05, 2017 | Cell Phones
Which pin is the protection pin of sansui 29 crt tv tda12062h/n1/foo in
Hi Shanmugam
Check and replace the horizontal scan output transistor. Why are you going before the protection pin?
Sep 19, 2016 | Sansui Televison & Video
I had on pin blocked and and i enter pin number while i am enter pin number the phone said that my sim had puk
you will get the puk code from the service provided in order to get make a call to customer care and tell your sim number
Apr 26, 2011 | Samsung Computers & Internet
What is MTN online assistatnce self service PIN number
Pls help me wit sucurity code, dis my numb 07067487974 pls i nid ugent pls
Sep 23, 2010 | Cell Phones
I forgot my mtn share n sell pin, please I need it urgently.
please I cannot remember my mtn share n sell pin... 08066219358.. Thanks
Aug 27, 2009 | Teac (DV-W58GA-PUK) Burner
I forgot security code of my mobile
The SIM card protects your subscription and not the phone from unauthorised users. If you change SIM cards you can still use your phone with a new SIM card. Most SIM cards are blocked at the time of purchase. If your SIM card lock is on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK is supplied by your service provider. You can edit your PIN and select a new four to eight digit number
  • If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
  • If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
To unblock your SIM card:
  1. When PIN Blocked appears enter your PUK > OK
  2. Enter a new four to eight PIN > OK
  3. Re-enter the new PIN to confirm > OK
To edit your PIN:
  1. > Settings > the General tab > Security > Locks > SIM Protection > Change PIN
  2. Enter your PIN > OK
  3. Enter a new four to eight digit PIN to confirm > OK
To turn the SIM card On /Off
  1. > Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
Jul 25, 2009 | Nokia 3110 Cellular Phone
I forgot my mtn share N sell pin
i forgot my mtn share n sell pin. and my line was block for share n sell
Apr 27, 2009 | Teac (DV-W58GA-PUK) Burner
Sony 36XBR800 Standby light flashes ...no picture sound
For 6 blinks,Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
I think this will help you to solve the issue.
Dont forget to Rate!!
Good Luck
Dals123
Apr 10, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Puk number
puk number is given by the network provider ....
i think you blocked the pin code by entering the wrong pin code for 3 times so it is asking for the puk code ..
to get puk code you must follow these steps :
1. call to your network provider customer care
2. tell them that your pin code got blocked you want puk code
3. if they ask any details about the sim card owner you answer that one ...
4. then make a note of the puk code and enter in to your cell
note :
if you enter the wrong puk code for more than 3 or 10 times your sim will get fully blocked you must purchase the duplicate sim card or you must contact the network provider shoppe ...
Mar 31, 2008 | Nokia N73 Cellular Phone
Puk code
please help my sim card is puk lock i nedd a code to unlock it
Dec 13, 2007 | Nokia 6600
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
