Question about Vacuums
I need a new bag for a wapVs300s combi cleaner
Which vacuum would you prefer for pet hairs ?
I've been repairing vacuums over 30 years, I prefer a bag vacuum because a good bag vacuum is a lot less maintenance, all the nasty stuff goes in a cheap paper bag (which is actually just a really good great big cheap filter) which you simply remove and gently sit in the trash. It usually takes less than 30 seconds to change bags and only needs done about once a month. You will dump a dirt cup about 40 times compared to changing one bag. Bags compact the dirt while bagless fluffs the dirt. Bagless filters and dust compartments need frequent cleaning and replaced at least once a year to work properly. Bagless vacuums leak more dust and dirt which you will notice on your vacuum. In the long run its much easier and cleaner using a bag vacuum plus they usually last much longer, usually outlasting 3 or 4 bagless vacuums. Much less expense and hassle in the long run.
Mar 05, 2018 | Vacuums
Light keeps blinking
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Manual for WAP Vs 300s Combi Cleaner 230V 50 Hz 1100W
I need a new dome for my Wap Vs 300s. Where can I get ons?
Jan 09, 2012 | Wap 28538 Wet/Dry Vacuum
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Dec 25, 2010 | Eureka Vacuums
I can't get replacement bags for my Bosch Premium 1300 W vacuum cleaner.
Greetings from GoVacuum,
Your Bosch Premium canister vacuum cleaner uses Bosch Style P Bags.
We carry 2 different types of Bosch Type G bags for your vacuum cleaner.
We have the genuine Bosch Bags Available for Purchase Here;
Bosch Type P MEGAfilt™ Super TEX Vacuum Cleaner Bags
And also in bulk buy here;
3 Pack Bundle Pack of Bosch Style P Vacuum Cleaner Bags Part #BBZ52AFP2U
And we also carry a generic paper style bag that doesn't filter as well as the cloth Bosch genuine bags, but is suitable if you don't have any breathing issues or allergies in your home. Here are the Bosch generic P bags;
Bosch Type "P" Canister Vacuum Bags Generic
I hope that this information was helpful to you. If this helped you, please be sure to rate this as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of my answer.
Feel free to email me at if you have any questions or need further help with your Bosch canister vacuum.
Thank you so much,
Chris Jones
Feb 22, 2010 | Bosch BSG81313UC Premium Bagged Canister...
Need vacuum cleaner bags for euro pro ep055
Needed bags for this vacuum and FINALLY found them at Ten bags and two filters for $10.95 plus shipping. Hope this does it for you and anyone needing bags for this vacuum.
Dec 12, 2008 | Euro-Pro EP055 Bagged Canister Vacuum
Electrolux ambassdor will not run after pluggen in
Greeting from GoVacuum,
On all Electrolux canister vacuum cleaners, there is a kill switch, that will not allow the machine to turn on without a bag in it. Sometimes when replacing the bag, the bag is placed in a position where the switch is not being activated.
When you open the bag housing, it should look like this;
You'll notice in the bottom right corner of the bag housing, the kill switch to the vacuum cleaner.
Try plugging the vacuum cleaner in, and while you are pressing this kill switch down, turn on the vacuum cleaner. Does the vacuum cleaner turn on/off when you push/release the kill switch? If it does, simply just get a new bag, and make sure that the new bag is covering the kill switch, and close the door of the vacuum cleaner.
If it still doesn't start, let me know and I'll try to help you diagnosis the machine differently. I'd say that 6 out of 10 times, this kill switch is the problem.
I hope this helps you. Please email me with any questions, or if this fix doesn't make your vacuum work. I really enjoy sharing my passion, and expertise in repairing vacuum cleaners.
Chris Jones
Oct 03, 2008 | Electrolux Vacuums
Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Sep 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
