Question about Ingersoll Rand Air Tools & Compressors
I have Ingersoll rand ssr Hp40 SE compressor.. I can't set pressure above 95 psi if it have discharge pressure 143psi..what should I do for set this? If pressure touches 95 psi automatically vavle opened..
    Master:
  • 481 Answers
The tank, compressor head, and components need be rated at what you want set the compressor unit pressure to, the safety valve will keep from exceeding the lowest of those limits. If you suspect the safety relief valve needs replacing because it has weakened, then replace the safety valve with one OEM pressure values
Posted on Aug 10, 2017
  • 89 Answers
SOURCE: Cant set my compressor to automatic start/stop mode
U NEED TO ADJUST THE PRESSURE SWITCH ON THE BACKUP TO A LOWER PSI. TO COME ON AFTER THE PRIMARY. EXAMPLE: PRESSURE SWITCH ON PRIMARY COMP. SET AT 140-175 PSI AND BACKUP SET AT 135-170 PSI. U CAN USUALLY TURN ONE CENTER SCREW IN THE PRESSURE SWITCH COUNTERCLOCKWISE TO LOWER THE PSI.
Posted on Dec 27, 2008
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 23 Answers
SOURCE: ingersoll rand model 235hnl serial 30t314956 very
Use pressure bypass for starting.
Posted on Dec 18, 2010
  • 54 Answers
SOURCE: What does alarm start fault
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Posted on Mar 29, 2011
nickwharton1
SOURCE: I installed a used Ingersoll-Rand
I've a ingersoll compressor ssr ep 20 which is shutting down on high airent temperature.
Posted on Jul 11, 2012
Ingersoll rand ssr 25 ep high discharge pressure.
Still believe it is the Minimum pressure check valve or the discharge line is plugged some where. The check valve may move freely at the disc but the piston should move (not so freely due to the large spring) keeping it closed. It should take about 65 lbs PSI to open check valve. Check it all again and if you find nothing you have a discharge line plugged some where.
Jan 10, 2018 | Ingersoll Rand Air Tools & Compressors
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
Troubleshoot overflow condition
Sounds like worn pressure control valve. I'd replace it.
Mar 04, 2015 | Ingersoll Rand XHP1170FCAT High Pressure...
I'm working on a Ingersoll rand 100HP stationary compressor with an intellisys 39875158 controller.
Make sure the model of your compressor is design for 160psi if not the main motor trip off and safe valve pop. Goto Main Menu, Operator setpoint+select, Offline/Online+select, arrow up and down to change value.
Jul 04, 2012 | Ingersoll Rand Stationary Air Cooled...
Ingersoll Rand SSR EP60 60hp Compressor w/ Intellisys 39817655 controller. Need to reset target pressure. What is the secret button sequence to access programming mode on this controller? I am aware of...
OK, Compressor should be shut down and showing (ready to start) in display. Press load/unload button once then press hidden right button within 3 seconds. This will let you access the set point program. It will include language, temperature and pressure, rated pressure,etc. Make sure you look at the data tag affixed to the unit and see what the rated pressure is for your unit. You can endanger yourself and equipment by over pressurizing the components of the compressor.
May 19, 2011 | Ingersoll Rand Stationary Air Cooled...
I am trying to fix an ingersoll rand hxp 50 se it starts and all sensors seem to work but it trips out on low unload sump on display and there isn't any faults in the manual that can lead me to the problem...
I would first look toward the Minimum Pressure check valve. You will have to remove several covers to access. It should be located on the end of the after cooler. Also the blow down valve will cause this problem if it does not close. These units do not have oil pumps and depend on air pressure to push the oil thru the system. When the air pressure drops below 15 psi in the sump the compressor shuts down. Also check the pressure transducer to make sure it's reading correctly. A pressure gage in the discharge line would be OK. Compare the Controller read out to your pressure gage. They should be close but could read 5 PSI or so difference.
Jan 12, 2011 | Ingersoll Rand Stationary Air Cooled...
I have an ssr-epe250 and need to change the pressure setting from online @93 & offline @ 103 psi. i need 125 psi. i just changed the controller and cannot get back to operating specs i need.
controllers do not come setup for a specific compressor. you need to be able to get into the factory setup.you will then be able to change rated pressure, horsepower etc. look at the name plate to get rated pressure. once the rated pressure has been changed you will be able to set your operating pressure to 125 online and 115 or less offline
Aug 10, 2010 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
105 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
