Question about Cameras
My Akaso EK7000 powers up but there is no image on the view screen
Table would not bootup. The word android keeps flashing on the screen, why?
My KF froze the same way. I found a forum where others had same prob and got the fix-it from them. It entailed holding the power button for about 45 seconds when device was off.
Nov 03, 2014 | AKASO KingPad 7 Google Android 4.1 Dual...
Lens screen stuck open and no image on LCD view screen.
It is jamming, the only really fix is to have it repaired, that costs a lot and it is sometimes better to just replace the camera.
Mar 15, 2014 | Sony Video Cameras
No image on screen when switched on. New batteries fitted. Canon Power Shot A60.
If your Canon A60 camera shows previously saved pictures in memory card in playback mode but does not show live view in camera mode than ccd imager chip in camera got defective and will be replaced.
Canon offers free of cost ccd imager chip replacement. Click Canon CCD Imager Advisory to avail that FOC service.
Thanks.
Jun 21, 2010 | Canon PowerShot A60 Digital Camera
Screen does not display image
make the "live view"/"viewing screen" first enable by locating it in your menu or your settings. then after that you can go back from taking picture by using the viewing screen
in regards of viewing the pictures taken, press the display button. keep pressing until the viewing screen appears
Apr 30, 2010 | Canon PowerShot G9 Digital Camera
No image on LCD screen
It sounds like you're receiving partial information on the LCD screen and that the image sensor isn't sending information to the screen.
If you know the sensor is working by recording some video on an SD card and being able to view the recorded video on your PC, then there is a disconnect between the LCD and the image sensor.
If you are not recording video to your SD card and only get black images or no files, the image sensor is damaged.
If you are recording video, but no image appears on your LCD for internal viewing/playback, you can try a firmware update if one is available from www.insigniaproducts.com, but this is a discontinued item so there's not much available for support.
Hope this helps!
Apr 25, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Image viewing
When you are viewing images then just check the OPTIONS menu. Their's a link to view the Image in Full Screen.
Else try the Star button on your phone.
May 01, 2009 | Samsung SGH-L700 Cell Phone
I can view the images taken, but when I try to take an image the LCD screen does not show the image, screen is black
hey my camera just did the same thing, have you tried replacing the batteries - i thought it couldnt be the batteries because the playback screen still showeed up just not the one to take photos but i just put in newly recharged ones and it can take pics again so maybe try that :)
Apr 22, 2009 | Fuji Finepix S6500FD Digital Camera
The display image unseen and the screen is dark
display shows ,saf, memory card ,charge symbols but not the capturing image on the display screen.After some time the camera is switches off.
It is sony cyber shot DSC- T33 .
Dec 10, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cameras Logo
51 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
