Question about Dual Computers & Internet
Dual battery system - Dual Computers & Internet
Vibration mode is not working on vibrate Mode as well as Sound Mode on my Samsung GT I8262
hear try or reset all if well done f we not ur hardware of cp is problem
How to Soft Reset or Reboot or Restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
There are several ways to do soft reset or restart, the easy way to soft reset or reboot or restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL by remove the battery and then put again to the place then turn on the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL. If you do not want to open the battery, you can do easily with pressing Power Button for several seconds and the option menu to turn off or reboot will appear.
#Option 1, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with software menu:
  1. Turn on SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  2. Make sure SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL battery is not empty
  3. Go to menu: Setting > Backup and reset > Factory Data Reset > Reset Device
  4. Choose Erase Everything
  5. SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will do the process to Master Reset to Factory Default, wait for several minutes.
#Option 2, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Hardware key button:
  1. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL charge properly
  2. Turn off SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  3. Press and hold together : Volume Up Button + Home Button & continue with Power Button (together)
  4. If we see the menu at LCD screen, choose Wipe Data/Factory Reset with Volume Button to select and use Power Button to ok or enter.
  5. The SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will doing the process of restoring to factory default.
#Option 3, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Secret Key Code Security:
  2. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL not empty
  3. dial or press number to call: *2767*3855#
  4. That number code will force format SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
How to Restore and Reinstall Clean Android Operating system / firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
Do not worry to do reinstall or restore the clean and default setting Android operating system or firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL because the file source already saved inside the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ROM. If we think the phone really need to be reinstall or restore the default Android operating system or firmware, then we can do it easily by doing hard reset or master format step above, because the operating system will be reinstall by itself.
goodluck sir.
Jul 04, 2014 | Samsung Cell Phones
How do i run a RE 5000.1 to one 15 in. cvx with out my battery lights dimming or battery getting drained
Better get a beefier alternator, something around 250-300 amp. A dual battery setup with a dual battery Isolator will take the load off the car system. Also a 2+ Farad Capacitor at the amplifier will cut down on surging.
Feb 02, 2013 | Re Audio XTX-5000.1
Ccm 644 misfire
Hi, Anonymous and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition and leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intake air leak.
8. Water, dirt, or rust in the fuel system, carburetor and/or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose, dirty, or corroded ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and/or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damaged intake or exhaust valve.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have nice a day.
http://forum.ccmmad.co.uk/topic/7175656/2
2003 CCM 644 Dual Sport Review Test Ride
Rotax Manual pdf
CCM Spares 644 Dual Sport
CCM 644 Dual Sport
Feb 25, 2012 | 2007 CCM 644 DS Dual Sport
Noise comes from the cordless microphones when the battery is getting flat. Is there an indicator which can tell me when the battery is about to get flat? I am using an MR-801 a system. How do I avoid this...
Hi, the noise is the sign that the battery is gong flat, that's how the mic was done.When it goes flat,it makes some kind of disturbed sound for you to know that the battery needs to be replaced.
It's normal.
Thanks for using fixya....
Oct 26, 2010 | Mipro MR-123D Dual Diversity And Dual...
Dual battery system
Double insulate the positive cable like with a heater hose the same length as the cable to make sure it does not rub into the cable anywhere.Use 1/0 cable,this will carry,and hold the volts and amps,on the ground,just use 1/0 cable from that battery you are putting in,to the nearest body bolt or frame.
May 20, 2010 | 1998 Toyota 4Runner
Wiring ??? I'm installing dual 12 volt battery's
pos to pos and neg to neg for 12 volt but if your system is 24 volt thats a different story it will be pos to neg.and pos to neg
Nov 02, 2009 | Ford F-450 Cars & Trucks
Have had dual battery system installed with
Visited local Toyota dealer and got copy of radio operation book relevent to my vehicle which contained info on how to fix. If I hadn't had security code Toyota dealer could have attached system to diagnostic computer and resolved the issue - not sure at what cost.
Sep 30, 2009 | 2003 Toyota Land Cruiser
Microtek dual ups battery
yeah, you need to replace the battery with the same kind of battery installed in it or you may consult with the technical support of microtek nearest you.
Sep 12, 2009 | Computers & Internet
Won't turn over
is the purple wire at the starter getting a 12 volt signal with the key held in the crank position? is the engine ground cable cklean and tight? are the starter cables ok?
Aug 09, 2009 | 1994 Chevrolet C1500
Computers & Internet Logo
22 people viewed this question
Top Dual Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
 Grubhead
Grubhead
Are you a Dual Computer and Internet Expert? Answer questions, earn points and help others
