Question about Sony Televison & Video
I can set timer on toshiba regza tv but when due to start recording nothing happens. I am trying to record to a Sony vhs recorder
Is it incorrect connection or do I need to set something on the recorder. I had no problem when using my old Sony tv
SOURCE: Toshiba DVR recorder incorrect disk message
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
  • 21 Answers
SOURCE: Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
Posted on Jan 23, 2009
SOURCE: How to Record TV Programs w/o Cable Box/Satellite Receiver?
Ok, I had this issue. And this is what you need. Even if you have a new HDTV, you need a converter box. The new TVs are not made to send out the signal just take it in. Best price I have seen on converter boxes was H.E.B
1. Antenna to converter box
2. Converter box to VCR
3. VCR to T.V
You will have to leave the converter box on when you are recording or leave it on when you leave the house. Also it has to be on the channel you are recording and the TV needs to be on channel 3 or 4. When you program your VCR it needs to be for the time and stuff. But put it to record channel 3 or 4. Which ever you pick for it to record off of. It really is easy. But I do hate that the people that had this great idea made it to where we can only record from one channel. I am going to try to send a diagram that I drew. Not the best artist, but you can tell what I mean. I can not seem to get it to attach the attachment. But you should not have a problem. Good Luck :-)
Posted on Apr 18, 2009
This is the link to the ZV420MW8:
Posted on Jun 07, 2009
SOURCE: I have a Magnavox ZV427MG9 A VHS & DVD Recorder
Ensure that your source is correct. L1 is the rear inputs and L2 is the front inputs. If you have it set to L2 then you have no information from the TV getting to the recorder.
Posted on Sep 23, 2009
Recorder stops recording from vhs tapes after about a minute
Some VHS tapes have copyright signals embedded in them. Then when the DVD recorder reads the copyright signal it will stop recording due to it thinking there is a copyright violation happening. Try testing with a VHS TAPE of a show you have recorded off the TV and see if it does the same thing .,
Mar 24, 2016 | Televison & Video
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Problem recording of hd tv with cable box from
Here are a few items to check and how you need to set your recording.
1. Your HD box should have a coax out (or to TV) connection on the back of the box.
2. Connect a coax cable from the back of the HD box to the "RF IN (FROM ANT.)" in the back of the VCR.
3. When you set your VCR to record you need to set it to copy channel 3 and tune the HD box to the channel you want to record.
This should fix your problem...
Good Luck...
Jan 07, 2010 | Toshiba W522 VHS VCR
Toshiba Television will no turn on, timer record lite flashes when trying to tur on T.V
Sep 05, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Timed Recording - Won't record VHS or DVD
Bought a new Sony DVD recorder/player with VHS.
Dec 29, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Hi again,
This is a placeholder and would look forward to the diagrams.
Jul 28, 2008 | Protron PD-DVR100 DVD Recorder
Won't timer record
- Does it have a tape inserted?
- Is the clock set?
- Is VCR off? (has to be off to be in timer mode for many VCRs)
- Is it recording but just plays back blank or does it not even start?
- If recording blank, make sure you are giving it a signal (Is your monitor hooked to the VCR output?)
- If timer doesn't start double check timer settings - they can be very tricky.
Nov 06, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Open Questions:
Televison & Video Logo
26 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
