Question about Cell Phones
Defy dryier is splnning not drying what could be the problem
Elec. clothes dryer turns but won't dry
If dryier is 220 V, phase is burnt out, so it's working on 110V, not enough to heat the air. Check your breaker and electric system or dryier.
Jun 02, 2015 | Dryers
Quick dry
Defy ( not listed in brands) For a speedier dry, leave the door open slightly when the second green (Dry) light comes on. The steam aids the dry process.
on Oct 20, 2011 | Dishwashers
Tumble dry wont turn and dry
check that your motor spins and your belt is on the drum. you say its heating so your door switch isn't the problem.
May 30, 2014 | Cell Phones
When should i change the timing belt on 2005 dodge caravan 2.4 engine
around 80.000 miles or 6/7 years depending on local climate ,dryier the climate then change it sooner as the rubber dries out
Jun 21, 2011 | 2005 Dodge Caravan
I would like to compare the shades of age defying foundation, where can I see a color chart on-line?? Thanks!
You can use the following link:
It would be better to go into a store and compare the colours, since the on line chart will not be reflected accurately. Also, when testing foundation, try it on your face not your hand since the skin is a different colour.
Jan 01, 2011 | Revlon Age Defying Liquid Foundation Soft...
If you don't want to open the case, you can use sprayer, find it in the market, contact cleaner (spray).
Spray the cleaner right into the fan rotor, and to remove the dust, use the paint brush or vacuum cleaner.
Hope it's work!!
Dec 09, 2009 | Maxtor Shared Storage II (S01R320) Hard...
Dryier doesn't dry is not heat
if your apliance is gas-dryer you need chek:
1-thermal fuse.
2-sensor flame.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
My maytag Dependable Care Quiet Plus 2 /gas dryier
Magyar quiet puls 2, does not heat, have to run 3 times to dry out. Is it usual?
Jul 28, 2009 | Maytag Dryers
The dryier does not heat
the problem are your gas coils are faulty
Jul 26, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
