Question about HP Office Equipment & Supplies
What is hp laser jet ip address - HP Office Equipment & Supplies
    Habit-Forming:
    New Friend:
  • 80 Answers
Check out this @ https://h30434.www3.hp.com/t5/Inkjet-Printing/How-to-find-your-printer-IP-Address/td-p/3214499
It could be helpful for you..
if you unable to fix your issues, please call me at 1800-204-4427. I can help you resolve that issue over the phone in a minute
Posted on Aug 09, 2017
    Top Expert:
  • HP Master
  • 48,434 Answers
Fixya would not know this check with the MODEM
SOURCE: driver hp laser jet 1020
hp driver 1020 downlord
Posted on Nov 05, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: install hp laser jet p2015
Please find below the link to download the driver.
I hope that the printer is connected via USB. If yes, please do not connect the USB cable before running the software. The software shall prompt you to connect the printer. Once prompted, please connect the USB cable and make sure the printer is powered on.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=LJ+P2015
- Nikhil
Posted on Nov 07, 2008
ziraffa
  • 827 Answers
SOURCE: I need to change the
Most HP printers can be reset to factory defaults (or cold-reset ) by turning the printer off and holding down the Online or Go button while turning the printer back on. The printer control panel display should read "Cold Reset" or "Restoring Factory Settings" or something like these lines. This will remove any IP address that the printer had previously.
When you plug it in, your router should have assigned an ip address automatically. Go into your router and look at the attached devices and it will show you what ip address has been assigned to each device on your network.
Use Web Interface or Manually Assign an IP address NOTE: Network HP Printers allow you to manage them via Internet Explorer. You can enter the IP address that the printer currently has and access its configuration settings. This assumes that the web interface hasn't been locked.
NOTE: We recommend that you install the latest version of Sun's Java software before trying these steps. See this How To: How to Update Sun's Java 2 Runtime Environment Plug-in.
  1. Print the Configuration page if needed. You will be entering the "current" IP Address.
  2. Open Internet Explorer. Delete EVERYTHING from the Address line.
  3. Enter the IP Address in the Address line and press Enter.
  4. You should then connect to the printer. If this fail, go to the next section to assign the IP address manually.
    NOTE: There are 2 basics versions of the web interface. Type 1 is on newer printers. Type 2 is on older models
  5. Type 1: Click the Networking tab.
    Type 2: Click the Administration button. Click the Configuration tab.
  6. Edit the IP address, Subnet Mask, and Gateway as needed.
  7. Do not change any other fields.
  8. Scroll to the bottom and click Apply. Click OK.
  9. Close Internet Explorer.
  10. Restart the Printer. Print the Configuration page to see if number was set.
NOTE: If the above steps do not allow you to assign the IP address via the Wizard, you will need to do it through at the printer itself.
  1. Go to this HP Support Page.
    Configuring TCP/IP through the Front Control Panel
  2. Click the link to your printer model. Highlight these steps.
  3. From the File menu choose Print. In the Page Range section, click Selection. Click Print.
    Note: For the complete printer user guide, go to the HP Printers Support & Troubleshooting page. Locate your specific printer type and model. On its home page, under self-help resources, click the manuals link. Download the printer's User Guide (not the Getting Started Guide). Look for steps to manually configure TCP/IP parameters from the printer control panel.
  4. Follow the steps from the printout to assign the desired IP Address to the printer.
    IP address will be entered at the IP BYTE prompt
    Subnet mask is entered at SM BYTE prompt
    Gateway address is entered at GW BYTE prompt
    Note: The syslog server IP address (LG BYTE 1=) and timeout (TIMEOUT=) do not need configured.
  5. Once the IP Address is entered, restart the Printer. Print the Configuration page to see if number was set.
Hope this helps
Chris (ziraffa)
Posted on Jan 09, 2009
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Posted on Jul 27, 2009
AlliedSOS
  • 82 Answers
SOURCE: how do i set ip address for new jet direct card on
Go here for the manual cause it's a bit hard to walkthrough. When the printer is on and ready, you want to click the menu button and scroll though to the configuration menu -> i/o menu. You can print a configuration age to see what the current address of the jetdirect card is. If you're comfortable with command line, you cna use telnet to connect to the jetdirect card and configure it that way.
Posted on Oct 05, 2009
I have hp printer 2035 when add to network not stop printing
If you have reused an IP address from an old or different printer then likely you have a stale print job that is spooling to the printer once you connect it and likely the driver is not compatible with the 2035. Try connecting the printer with a different address to see what happens.
May 12, 2016 | HP LaserJet Office Equipment & Supplies
HP Laser Jet M1005 Printer IP Address
Print to the printer from your computer.
Now run, in a command window,
Arp -a
This will list the recently used IP addresses.
Feb 10, 2015 | HP Office Equipment & Supplies
Hp laser jet p 2015 ip address
Umm, yeah..... you have to be a little more specific.
Feb 10, 2014 | HP LaserJet P2015dn Printer
Configure ip adress to hp laserjet p3015
This model does actually have embedded network functionallity.
To configure the IP Address, follow the menu map as below:
1) - (4) I/O
2) - (4-2) Embedded JetDirect Menu
3) - (4-2-2) TCP/IP
4) - (4-2-2-1) Enable (Make sure this is 'On')
5) - (4-2-2-3) IPV4 Settings
6) - (4-2-2-3-1) Config Method (Auto = DHCP, Set to Manual in order to specify an IP address.)
7) - (4-2-2-3-2) Manual Settings (This is where you can set the IP Address, Subnet Mask, and Default Gateway.)
Apr 28, 2011 | HP P3015 Laser Printer
I have hp laser jet 1320 n printer.. I want to set ip for this printer .. How I will set ip for this printer.
To configure the IP address of the HP LaserJetand set it up as a network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Nov 04, 2010 | HP LaserJet 1320 Printer
How to install HP laser jet M1522nf and connect my
How are you connecting this printer to your computer ? usb or network ?
If its network i would recommend you to make sure that the IP Address on the printer matches with the one set on the printer driver on the pc
Tryn reinstalling the software a detecting the printer automaticly
Jul 07, 2010 | HP LaserJet M1522nf Multifunction Printer...
What is the Hostname of hplaser jet M1522nf
Any queries regarding Ip-details, please log in to, http://www.ip-details.com/ which gives you the latest information and a accurate solution for your search.
Jun 04, 2010 | HP LaserJet M1522nf Multifunction Printer...
Connecting HP Laser Jet to network
If you can ping it you can print to it. You simply need to add the proper network printer drivers, and the IP address for the printer to your network on EACH computer tha t you wish to access the printer. It is not hard to do but is not a brainless windows automatc set up either. You can download the drivers from many places including www.feedrollers.com which deals with parts and accessories for these printers as well as all the manuals, users AND SERVICE, that you will need. By the way, I used to be an HP service tech... I even go to feeedrollers for my own use...
Feb 04, 2010 | HP LaserJet 5si mopier Printer
35 people viewed this question
Ben Johnson
